91 Options Codes : Need help deciphering?
Old Dec 21, 2001 | 09:40 PM
vmaxer's Avatar
vmaxer
Default 91 Options Codes : Need help deciphering?
Hi: I have a long list of options code off my car. Where in the world can I go to find out what goodies I got with my recently acquired 91 6 Spd.
Happy Holidays
Old Dec 21, 2001 | 11:01 PM
SLICKMAN's Avatar
SLICKMAN
Default Re: 91 Options Codes : Need help deciphering? (vmaxer)
Post your codes and I can tell you. You can also go a spend about $15 and buy and book called "Corvette Black Book" and that will list everything.
Old Dec 21, 2001 | 11:27 PM
JohnOH327's Avatar
JohnOH327
1991C4 is right. Get the Black Book. It has all the option codes for all Corvettes. Your list of options should be under console compartment door. Enjoy your Corvette. John
Old Dec 22, 2001 | 10:41 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Post your codes and save the $15! :)
Old Dec 22, 2001 | 03:42 PM
vmaxer's Avatar
vmaxer
Default Re: 91 Options Codes : Need help deciphering? (1991C4)
Here are my codes..... I really appreciate the help
AC1 AC3 AJ3 AQ9 BGR CF7 C68 DL8 D3X D8I E5Z E9Z FE1 FX3 GM3 G87 IL3 JL9 KC4 K68 L98 ML9 MN6 NA5 NK4 QA1 R8J UX0 U1F U52 U75 V73 XAU YAU 1AZ 1SB 19I 193
Old Dec 22, 2001 | 04:23 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
You can look them on Corvetteactioncenter.com http://www.corvetteactioncenter.com/tech/rpo1.html http://www.corvetteactioncenter.com/tech/rpo2.html http://www.corvetteactioncenter.com/tech/rpo3.html
Old Dec 22, 2001 | 08:43 PM
SLICKMAN's Avatar
SLICKMAN
Here ya go!! My web site has this info too..
AC1=ADJUSTER, PASS ST, POWER, 6 WAY, BKT
AC3=ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AJ3=RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AQ9=SEAT, FRT PASS A DRIV, RECL
BGR=?
CF7=ROOF, SUN REMOVABLE NON‑TRANSPARENT
C68=?
DL8=MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
D3X=STRIPE, DELETE
D8I=?
E5Z=SPEEDOMETER ADAPTER (DELETE)
E9Z=SPEEDOMETER KEY (DELETE)
FE1=SUSPENSION SYSTEM, S0FT RIDE
FX3=RIDE & HANDLING, AUTOMATIC ELECTRONIC CONTROLLED
GM3=AXLE REAR, 3.45 RATIO
G87=?
IL3=TRIM INTERIOR DESIGN
JL9=BRAKE, SYSTEM, PWR, FRT a RR OISC, ANTILOCK, FRT W
KC4=COOLING SYSTEM, ENG OIL
K68=?
L98=COOLING SYSTEM, ENG OIL
ML9=TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.53 1ST,
MN6=MERCHANDISED TRANS, MAN 6 SPD PROVISIONS
NA5=EMISSION SYSTEM, FEDERAL, TIER O
NK4=STEERING WHEEL, SPORT LEATHER W/ RADIO CONTROLS
QA1=WHEEL, 17 X 9.5, ALUMINUM, STYLED
R8J=?
UX0=SPEAKER SYSTEM, 4, DUAL FLR SILL, DUAL EXTD RANGE
U1F=Stereo System with CD, Bose
U52=?
U75=?
V73=ANTENNA, FIXED
XAU=TIRE FRONT, P275/40ZR17/N BL R/PE ST TL HW4
YAU=TIRE REAR, P275/40ZR17/N BL R/PE ST TL HW4
1AZ=?
1SB=OPTION PACKAGE 02
19I=?
193=?
[Modified by 1991C4, 7:45 PM 12/22/2001]
Old Dec 22, 2001 | 09:21 PM
Wildride's Avatar
Wildride
BGR - Bowling Green Assembly Plant
C68 - Air conditioning, Front, Automatic Controls
D8I - ????? (There is a "D81" which is "Spoiler, Rear, Aero Wing".
G87 - Gear Ring 8.50 inch
K68 - Generator 105 Amp
R8J - ????? ("R8" series are usually some sort of "Control Sales Item No. ##, Processing Option" whatever that is)
U52 - Cluster, Instrument (Electronic)
U75 - Antenna, Power (Chrome)
1AZ - ????? (is this a typo/transposition)? There is a "1ZA" which is "Sold Orders, Processing Option"
19I - Interior Trim, Black
193 - Trim Combination, Black Leather
[Modified by Wildride, 7:26 PM 12/22/2001]
To 91 Options Codes : Need help deciphering?
