Fixing a Scratch
Old Jun 15, 2008 | 09:25 PM
Myrtlmoose's Avatar
Myrtlmoose
Default Fixing a Scratch
I have a scratch about 2 inches long above the wheel well on a black 94 lt-1....
Can anyone give me good recommendations on how to fix it?
Daily driver
Old Jun 15, 2008 | 09:27 PM
pianoguy's Avatar
pianoguy
http://www.langka.com/
Or, if it's not through the clear coat, you could wet sand carefully with 2000 grit, and buff it out if you have a buffer.
Old Jun 15, 2008 | 09:32 PM
StealthLT4's Avatar
StealthLT4
I don't know what quality fix you're looking for, but I've heard that nail polish works VERY well. It won't match perfectly, but will mask it satisfactorily for most people, and it's cheap. Also, if you don't like the look some nail polish remover will take it right off! I've been meaning to try it with some paint chips of my own, but haven't gotten around to it yet.
Old Jun 15, 2008 | 09:38 PM
ragged claws's Avatar
ragged claws
I'd be really careful using nail polish remover around the paint surrounding the scratch!
Old Jun 15, 2008 | 09:49 PM
Myrtlmoose's Avatar
Myrtlmoose
Default thanks for input
Thanks for input...a little nervous about nail polish though...any other suggestions?
Old Jun 15, 2008 | 10:05 PM
pianoguy's Avatar
pianoguy
The nice part about the Langka kit is the blob remover - if you booger up your touch-up, you can use it to clean off the paint and start over.
Old Jun 16, 2008 | 12:09 AM
Lrod's Avatar
Lrod
I've tried the Langka, with some success. It covers the scratch and you have to build it up. It'll never be perfect, but it's better than a scratch.
Old Jun 16, 2008 | 01:13 PM
rickneworleansla's Avatar
rickneworleansla
I tried using Langka a couple of weeks ago. Maybe I did something wrong. It smeared the touch up paint down the side and completely removed it out of the scratch. Guess I need to go clean up the smeared paint and start over. Anyone else have trouble with it?
Old Jun 16, 2008 | 01:42 PM
pianoguy's Avatar
pianoguy
Go to their web site - they have some more detailed instructions and techniques.
Old Jun 16, 2008 | 02:08 PM
GKK's Avatar
GKK
Daily driver
The only way you can make a DEEP scratch (below the clearcoat), disappear 100% is to take it to a body shop where they will sand out the scratch and surrounding area, primer to fill in the low areas, wet sand the primer using 400 grit on a stiff foam pad then prepping the entire panel to blend the color from the scratched area onto the original color and then clearing over the entire panel. Color sanding and buffing should also be done. Costs around $500 depending on labor rates.
Minor surface scratches on the clear coat can be buffed out.
Old Jun 16, 2008 | 05:35 PM
Keystring's Avatar
Keystring
Air brush.
We used to do scratch repair at new car and used car dealerships using and air brush .
Once the paint is thoroughly dry just use a light buffing compound like ebony polish and buff the overspray off.
The paint in the scratch will still remain.
Practice using an old piece of painted metal to find the right distance and setting on the air brush.
You can do it a few times to build up the paint in the scratch.
Then just wax.
Does a good job of hiding the scratches.
We used to get payed $15 per car back in the 80's.
One dealer ship had over 300 cars we had to do.
Made a little money that month.
Old Jun 16, 2008 | 06:11 PM
jeffyc's Avatar
jeffyc
take it to a quality paint shop, they if they can they will buff it out, and it will be worth what ever they charge.
my dog scratched up my drivers side door of my new truck and coach works (who have since painted my vette) took out the scratches for free
the scratchs buffed out
Old Jun 16, 2008 | 07:29 PM
C4boy's Avatar
C4boy
It's worth a shot to get the right touchup paint for your car and try it yourself. If you don't like the results, you won't be out more than $20-$30. You may surprise yourself with the results. I've used the Mother's chip repair, which is the same as Langka, and it works very well if you use it within 5-10 minutes of applying the paint. And it's safer than wet sanding.
Here's some before and after pics using touch up paint.
To Fixing a Scratch
