Putting Vette back together question...
Old Jun 17, 2008 | 06:58 PM
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
St. Jude Donor '06, '07, '11, '17
Default Putting Vette back together question...
I'm attempting to put the '90 back together and I'm encountering some problems. First while trying to install the alternator/airpump there is a big gap where one of the bolts go through. I assume something is supposed to go in there but I don't know what. Here are a couple pics to show what I mean.
Also, I have a bracket that I currently do not know where it goes. It's the one circled in the pic. Any idea where this goes?
Thanks for your help.
Old Jun 17, 2008 | 07:28 PM
Joe C's Avatar
Joe C
...just put my son's 85 back together, and i don't know it if the 90 is configured the same way, but it looks like you might need, and i don't know the correct term for this but, a one piece stud with a bolt head in the center part of the threads. that way, you mount and tighten the power steering pump/bracket, and then the smog pump bracket. ...just my best guess. can't think of where the bracket goes - ??? hope this helps...
Old Jun 17, 2008 | 08:13 PM
blkvette85's Avatar
blkvette85
I could try to take a couple photos of my 91.
Are they the same?
Old Jun 17, 2008 | 08:27 PM
JackDidley's Avatar
JackDidley
Knooger, there is a stud that goes in that bolt hole. Has a nut made on it. Then the second bracket and another nut. I dont think that black rod installs that way though. My 87 has one that goes back to the intake. No clue on the one in the lower pic. Must not be there on my 87.
Old Jun 17, 2008 | 09:20 PM
floridamale's Avatar
floridamale
I think the lower one goes from the manfiold to the air pump
Old Jun 17, 2008 | 10:13 PM
Dads90's Avatar
Dads90
can't tell how long it is, but is it the holding bracket from the AC compressor to the anchor point next to the headers ?
Old Jun 17, 2008 | 10:22 PM
Dads90's Avatar
Dads90
In picture number one there is a bolt that has a second nut that goes between the aluminum bracket and block piece (works as a spacer). Then a nut tightens down onto the steel bracket.
Old Jun 17, 2008 | 10:56 PM
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
Excellent, thanks for the info. Stud with a nut in the middle makes a lot of sense.
Old Jun 17, 2008 | 10:57 PM
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
Are they the same?
They are both L98s, if you can find the long bracket on your motor I'd love a pic of that.
Old Jun 17, 2008 | 11:04 PM
Dads90's Avatar
Dads90
Figure out what the longer bracket was for ?
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Ok, if you have not messed w/ the AC compressor, then it is the support rod from the alt to the inside bolt on the exhaust manifold on #1 cylinder.
Old Jun 18, 2008 | 07:07 AM
bd2626's Avatar
bd2626
I think he's right, the long one from the ac to beside the header, the other does look like it's off the back of the air pump to the intake.
Old Jun 18, 2008 | 09:33 PM
redcloud35's Avatar
redcloud35
I know for sure, I just removed it last weekend while changing my plugs.
Old Jun 18, 2008 | 09:51 PM
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
I'll look into that. Thanks.
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
We just did that one, it was difficult.
Old Jun 20, 2008 | 12:48 AM
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
Yes, it is. And I have it installed now.
Thanks for all the help.
To Putting Vette back together question...
