Purple windshield?!
Deduct on condition for scratches, racks, delaminating and pitting.
Deduct on originality for incorrect manufacturer.
Two letters placed below the LOF logo on the glass, represent glass date codes. The first letter in the code identifies the month of production; the second letter identifies the year the glass was manufactured.
Full credit is given for a windshield dated within 12 months prior to the vehicles assembly.
Deduct 20% for correct winshield dated outside the above range
Deduct 50% for incorrect replacements.
In the opinion of the judges, the condition of the windshield constitutes a safety hazard in the operation of the vehicle, additional deductions may be made up to 100% on condition. Such deductions require concurrence of the judging team leader or the meet judging chairman.
Not even a coating. A vacuum deposition (sputtering) would be ten times better than a "tint" film laminated to glass.
You ever see sunglasses de laminate?
http://www.zr1netregistry.com/forum/...ght=windshield
Feel free to keep replies here, I just didn't want to cut/paste the post
How would it de laminate if it were sandwiched in between Glass?
There are two ways to filter Photons through a lens.
One is you coat the actual lens
Two you put something else in front of the lens like a filter or poylmer membrane.
What you said was correct, that article that you posted did say that.
I don't question your explanation, I question the document that you got your info from.
I'm diggin' a little deeper today.
As a side bar, I make Photon filters everyday. My filters allow you to look directly at the sun and study the pools and solar rays...
...you give me a light wave and tell me what frequencies you want removed and we'll do it...I can put a purple hue on glass, I'd just like a better explanation of what the General used when making these so I can offer up a similar item....seems this is a huge issue for the Z guys.
I can print a date code, I can mask an area........it won't cost you $2700 that is for sure
My point is this, If I can duplicate what GM did it would work for the NCRS guys....if I can't the rest of you can get a purple hue on your windshield for cheap.
Vacuum depositing material on glass is an a everyday occurrence, Most are limited by not having a chamber large enough to fit a C4 windshield inside to coat it....I have 10 chambers.....how many purple tinted windshields do you want.....this week?? how 'bout next?
If there's something you want me to test or check on mine, I'd be happy to (as long as it's non-destructive).
I suspect if you could make windshields that looked the same for cheap, you'd have plenty of buyers. If you started with an OEM C4 windshield, perhaps all the better. I suspect they are either LOF or PPG.
I've got a call into one of my associates to see what precursor is need to get that hue of purple on glass.
And anything over $500 I'll be taking and filling orders.......
Finally, what do you mean you've heard nothing but crap from safelite?
A) they have crappy glass (could be)
B) They tell you things that are not correct when you called them looking for purple tinted glass...
just guessing
The windshields were specially made because of the HEAT given off from the ZR1 motors. You can't just coat the under side of a windshield and get people to pay $1000, plus.
Though it's also possible they just wanted to try it out since it was new technology? I'd also sort of think most heat comes through that huge rear window. Maybe it just wasn't feasible to coat that? Or maybe it would look dorky with a purple rear window?
Understand, my thinking is less than half that amount.
here is the deal, NCRS buyers may not be interested if they want to win the competition, but many others may be...and if you have to get a new windshield because of a rock chip or a large crack....well, wouldn't a Z windshield interest you for just a few bucks more??
And if I could see a Z windshield and we find that we can duplicate it exactly....I'll go for it.
Now, a bit of coating technology. Let's return to chamber size. The late 70s and mid 80s chambers weren't very big and coating technology was really pretty basic. We've learned tons in 30 years. Uniformity, surface prep, surface activation for the purpose of adhesion promotion......(this is the reason the originals are de laminating, poor adhesion)
So this is why I'm dabbling with this idea.
I like constructive criticism as I'd like to NOT get in deep with this and it turn out to be rejected for this or that.
So be constructive and ask questions that would make or break a deal for you, and I'll see if I have a solution to your question.
