Door Post
Old Jun 25, 2008 | 03:04 AM
gregbetz's Avatar
gregbetz
Cruising
Default Door Post
Hi
Last year i replaced my weatherstrip all around my 89 convert and now
the driver door shuts even harder then it did before the pass side works great but it seems the pass side dont close as far in as the driver side.
Is there a way to adjust the door post?
I took the door post out to see if i can move it like the hayes says
and nope the hole is just as big as the torx bolt no movment there.
Old Jun 27, 2008 | 02:47 PM
gregbetz's Avatar
gregbetz
Cruising
Help!!!
Any One....
Old Jun 27, 2008 | 03:02 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
If you can post pictures of what you're talking about it might help. What are you trying to adjust?
Old Jun 27, 2008 | 03:04 PM
69mako's Avatar
69mako
Are you talking about the "striker" post that catches the door catch?
There is not an adjustment for that.
What I would look at is the weather strip around the door might be out of place, causing the door not to close correctly.
Also try posting this in the "tech" section
Old Jun 27, 2008 | 03:37 PM
gregbetz's Avatar
gregbetz
Cruising
The striker thats it.
Yeah hayes says you can move all around didnt think so.
This door has just allways shut way in to the body compared to
the other side.
Thanks!!!
Old Jun 27, 2008 | 03:40 PM
69mako's Avatar
69mako
You have a PM
To Door Post
