bump steer?
Old Jul 2, 2008 | 02:08 PM
ragged claws's Avatar
ragged claws
Default bump steer?
What is it?
Old Jul 2, 2008 | 02:57 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
http://www.naxja.org/html/techarticl...psteertech.htm
Bump-steer is the result of poor (and sometimes unavoidable) suspension geometry. The reaction is described as the vehicle steering off the intended track, on it's own (without driver input), when encountering a bump. Sometimes it is described by a driver as the vehicle needing constant direction correction whenever driving over a bump, "I hold the steering wheel straight but the vehicle steers to the right every time I hit a bump."
http://www.bakerprecision.com/longacr17a.htm
Bump Steer
Bump steer is the toe-in or toe-out of the front wheels as the suspension goes from normal ride height through full bump (suspension system moves up) to full droop (suspension system moves down). Measurement is usually limited to 3" up and 3" down from ride height. It is specified either by a graph or measurements at 1", 2", and 3".
Bump steer affects handling much as setting toe-in does. All cars have a certain designed-in pattern of bump steer. Check with your chassis builder for his normal pattern. If you have a factory chassis, you'll probably want to try to minimize bump steer as a starting place.
Old Jul 2, 2008 | 05:03 PM
Eakster's Avatar
Eakster
Mine has it pretty noticeably when cornering and hitting a bump -feels like the whole front end shuffles sideways momentarily. I'm not sure how badly all C4s have this problem
Part of the problem is the transverse leaf springs as shocks can be transmitted from one wheel to the other, unlike with a coil-over setup
Old Jul 2, 2008 | 07:26 PM
ragged claws
Thanks for the info and links, Redeasysport. Most of the info is over my head but I think I kind of understand the symptoms. Sometimes when I hit a bump the steering wheel "wiggles" for a while then settles down. Thought it might be a wheel balance problem but it doesn't happen at just one speed and sometimes not at all. The roads around here are in poor repair with a lot of bumps and uneven surfaces. I need to take it on the freeway and check it out. My mechanic said that all of the suspension parts seemed ok but I don't know how hard he looked. It seems from the info in your post that steering wheel wiggle is not a symptom of bump steer.
Thanks, Kim
Old Jul 2, 2008 | 07:38 PM
Redeasysport
Wiggles up and down or left to right? Bump steer actually takes the car in a different direction that requires turning the wheel to keep it on track.
Old Jul 2, 2008 | 07:53 PM
ragged claws
Not really sure but I think it wiggles left to right. I do get a little going off in another direction after a pretty good bump but nothing severe. The car only has 56K on it so I'm thinking it's probably not worn suspension parts. Wheels and tires are pretty new and have been balanced and I had a 4 wheel alignment done about 4 months ago.
Old Jul 2, 2008 | 10:02 PM
Redeasysport
There is also body flex on top of bump steer that make these cars feel unstable on bumpy roads. From what you say it may very well be normal 'Vette response to crappy roads.
Old Jul 2, 2008 | 10:30 PM
Lrod's Avatar
Lrod
I had those symptoms, but it seems as the body flex, old shocks, worn suspension, worn tires all contribute. As I replaced shocks, rotated tires, and made some other minor adjustments the effect has faded to a degree. Not all C-4 came this way from the factory, and the effect has to be at different levels depending on component age. Any opinions?
Old Jul 2, 2008 | 10:33 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Early and late mode C4's have a different suspension geometry, the later ones are call zero scrub.
Alignment can fix that darty feeling, both early and late.
Stock the cars have positive camber, they lean OUT
Set them to about 1/2 a degree in all around, about 1/18 toe in on the front and 1/8 toe out in the back, and you'll really like the way it drives from day to day.
Old Jul 4, 2008 | 01:11 AM
DCP's Avatar
DCP
Originally Posted by ragged claws
What is it?
FWIW...
http://forums.corvetteforum.com/show....php?t=1749848
Old Jul 4, 2008 | 11:51 AM
redrose's Avatar
redrose
What is it?
suspension designers refer to upward movement of the wheel relative to the chassis as "bump"...downward motion is "rebound"
lengths of suspension components cause changes of wheel tracking as the wheel moves up in "bump" or down in "rebound" and these tracking changes are highly desireable to prevent loss of operator control during cornering (bump steer "out" of the outboard wheel is prefered to "0 bump" or "in") , but may cause undesireable tracking inputs when road surface variations (aka bumps) are encountered during straight line operation.
note that wheel movement in bump or rebound during cornering is produced by "body roll"...so "body roll" is not all "bad"
To bump steer?
