86 E Roller Rocker and Valve Spring ?
Old Jul 2, 2008 | 05:21 PM
LKoncar's Avatar
LKoncar
Default 86 E Roller Rocker and Valve Spring ?
I need to replace valve stem seals on my 86e and thought I would do springs and 1.5 roller rockers while I'm in there. This is stock except for y-cat delet and high flow main cat.
So do I need 1.5 3/8 self aligning rockers ? and also what kind of springs should I go with?
TIA Larry
Old Jul 2, 2008 | 06:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I suggest 1.5s on the exh with new stock springs and 1.6s on the int with Comp Cams 981 springs.
The exh valve uses "rotator" to avoid burning the valve/seat.
New forged keepers and new valve stem seals would be a good idea too.
Old Jul 2, 2008 | 10:49 PM
LKoncar's Avatar
LKoncar
So do I use self aligning rockers for this? Also can you buy these in the split sets or do you have to buy both full sets of 1.5 and 1.6 ? Thanks, Larry
Old Jul 3, 2008 | 12:44 AM
project C4's Avatar
project C4
Default no self align on factory iron head motors
i just had the valve covers off of my e86 yesterday. when the heads have the small hole were the pushrods come through dont use self align. the small hole on the heads keep them lined up. most factory cast iron heads are like this.
Old Jul 3, 2008 | 08:03 AM
silver86's Avatar
silver86
New springs aren't necessary if you're just changing to a 1.6 ratio as suggested above. But, as long as you're going to have them off anyway......
Be sure to trim back the drip tabs in your valve covers if you're re-using the stockers and stepping up to the 1.6 ratio.
Old Jul 3, 2008 | 08:08 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You will need non self aligning rockers. I think I have seen split sets available online, just don't remember where.
Old Jul 3, 2008 | 09:29 AM
LKoncar's Avatar
LKoncar
Thanks alot guys for the info now I can get some parts together. I'm gonna go with Edelbrock Elite covers (short), New springs, Seals, Keepers and the 1.5 /1.6 combo. Thanks again, Larry
To 86 E Roller Rocker and Valve Spring ?
