VOLTAGE Problems.......
Old Jul 21, 2008 | 03:11 PM
vettecollector's Avatar
vettecollector
Default VOLTAGE Problems.......
The alternator on my 93 blew apart last week (chunks of metal all over). I drove about 50 miles in the desert to get to a shop. It has since been replaced by a new Alt. Now my voltage drops when the car is stopped and in gear with the A/C, headlights and radio on. When my turn signal is on it flashes really slow and dims my gauge lights. Sometimes "SYS" flashes by the speedo and "SECURITY" also flashes at the same time. Any ideas? Thanks
Old Jul 21, 2008 | 06:47 PM
RACER 1993's Avatar
RACER 1993
What does the voltage reading on dash say. With a new alternator I should be well above 13 Volts.
Did they install the same alternator with the same current rating?
Old Jul 21, 2008 | 07:34 PM
vettecollector
It sits at 13.9 - 14.3 Volts during the day with A/C on and moving. At night with A/C, radio and headlights/turnsignals it sits at 11.8 - 12.8 Volts with a very slow signal and dim dash lights. It was replaced at a Corvette only shop.
Old Jul 21, 2008 | 08:37 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It is more important to know what the battery reads with the key on. I would expect it to read what it does when running with a new alternator but if the battery is toast you will get sys light. Turn the key on and look at the volts if it is less than 12.1V you probably need a new battery.
Old Jul 21, 2008 | 08:44 PM
93v's Avatar
93v
The old alt. may have fried the battery just before ittook a dump
Old Jul 21, 2008 | 10:03 PM
jfb's Avatar
jfb
Don't bother with the dash voltmeter reading when the engine is not running, it is in error with the engine off! The alternator should be able to hold up the electrical load, that is, the dash voltmeter should read about 14.3 volts cold and 13.3 volts hot. If the alternator is not charging the battery, the red battery symbol will light on the dash. The alternator cannot put out rated current at idle and if you have unusually low idle rpm (below 700 rpm), or if someone put a larger pulley on the alternator, or a smaller crank pulley to reduce the parasitic load for more hp, then your battery will supply the car electrical load at idle and you will see low voltage. The battery is considered discharged at 12.0 volts and below and it should be charged up at least overnight with a battery charger. You can tell the state of charge in your battery by measuring the voltage at the battery terminals with a voltmeter while under no load. 12.0 volts and below, discharged. 12.9 volts and above, fully charged and linear in between. I don't believe your electrical load is excessive.
Your dash voltmeter should never show below 13 volts if idle rpm is 700 or more rpm and you have OEM pulleys! If below 13 volts, then you have a defective alternator.
Old Jul 22, 2008 | 12:05 PM
vettecollector
Thanks guys. I will have the new Alternator checked. It only stays at 13.9 during the day while I'm driving.
To VOLTAGE Problems.......
