climate control
Old Jul 22, 2008 | 11:14 PM
toyvet1's Avatar
toyvet1
Default climate control
I have a 1990 Zr1 with auto climate. The reading on the display shows -34 all the time. I was able to get a code 3 and replaced the outside temp sensor. Both sensors are within specs (2500 ohm at 77 degrees) Im thinking it might be the head unit? Any ideas , thanks
Old Jul 23, 2008 | 12:01 AM
Goldcylon's Avatar
Goldcylon
That would be my guess did you run the tests as detailed in the FSM ?
Old Jul 23, 2008 | 12:04 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Did you disconnect the battery to reset?
Old Jul 23, 2008 | 01:11 AM
Goldcylon's Avatar
Goldcylon
Good point.
Old Jul 23, 2008 | 12:53 PM
SunCr's Avatar
SunCr
If that doesn't do it, you need to trace the wiring from the sender to the Programmer to make sure that it's not open.
Old Jul 23, 2008 | 01:27 PM
toyvet1's Avatar
toyvet1
Battery reset was done and did not work. As for the manual nothing applies once the code goes away as it did when I undid the battery. Now when you check for codes you get normal. I have access to a controler and will swap that out and see if it helps.
Old Jul 23, 2008 | 01:39 PM
SunCr's Avatar
SunCr
Did you try grounding the lead? That should give you max at the controls.
Old Jul 26, 2008 | 05:51 PM
toyvet1's Avatar
toyvet1
Ground what lead?
As of now I have had a chance to replace the head unit and no change. Next I replaced the programmer and no change.
I have followed the manual and leads to a dead end. It never addresses this issue.
The display will start high and slowly drops and now settles around 50 degree.
Im stumped, any ideas
To climate control
