will not start warm
Old Aug 3, 2008 | 07:28 AM
looney1316's Avatar
looney1316
Default will not start warm
1990 6sp starts and runs great, when warmed-up (temp stays at 160) will not start,let it sit and it starts right up had it out last night for a run with friends ran fine up over 100 mph but ever time we stopped we had to wait for me to cool down to go i do not like being afraid to drive it ,it takes some of the fun out it.this is what i know, new ecm, fuel pres. around 40,have spark,idles around 1100 if we turn it down to 800/900 where i think it is suppost to be it kind of idles rough up and down a little so we put it back to 1100 rpm.also at the end of the night on my way home it shut down on me for a split sec (light and everthing when moving down a back road)like a little gremlin ,freaked me out but kept running fine the 4 more miles home, like clock work it did not start once home in the garage.also no major mods on car i had it for 1 yr 106000 miles i put on about 1000.thanks for any help i don't want to keep feeding her parts just for the heck of it
Old Aug 3, 2008 | 08:36 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
HERES A COUPLE OF THREADS YOU SHOULD VISIT
http://forums.corvetteforum.com/show....php?t=2055839
http://forums.corvetteforum.com/show....php?t=2055067
Old Aug 3, 2008 | 11:12 AM
schrade's Avatar
schrade
So you just got it...
Now get FSM volume 2, and a multimeter. Don't let dust get on it either...
Old Aug 3, 2008 | 12:31 PM
looney1316's Avatar
looney1316
i got the fsm's and a meter will get on it as soon as i can
Old Aug 3, 2008 | 02:03 PM
Powersmokin's Avatar
Powersmokin
hold the gas peddle to the floor when you start it I bet It will start
Old Aug 3, 2008 | 06:05 PM
looney1316's Avatar
looney1316
no it will not
Old Aug 3, 2008 | 11:53 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Do you smell gas when it won't start?
You are going to need to have the car scanned and check out the Coolant Temp Sensor. I acts like a choke on a carb, and if it goes bad, it will send the wrong info to the ECM (computer) and the ECM will flood the engine w/ gas.
Randy
Old Aug 4, 2008 | 06:33 AM
looney1316's Avatar
looney1316
no gas smell
Old Aug 4, 2008 | 07:39 AM
Aaron71771's Avatar
Aaron71771
Does it crank over?
Old Aug 4, 2008 | 07:52 AM
ghoastrider1's Avatar
ghoastrider1
if were older, thats a classic "coil going bad" sign. When that happened to me, I would pour a bit of water over the coil(s), and it would crank right up.
Old Aug 4, 2008 | 04:16 PM
looney1316's Avatar
looney1316
will crank but not fire
Old Aug 10, 2008 | 12:24 AM
looney1316's Avatar
looney1316
can my injectors be causing this problem,here is what i got. tested cold.1-16,2-16,3-10,4-8,5-5,6-16,7-9,8-16//tested hot(will not start).1-16,2-16,3-10,4-8,5-5,6-16,7-7,8-10 i know i need new injectors but can it be causing my problem if 2 of them drop off a little more when hot.funny thing is it still run with only a little miss and no rise in temp i stay around 160.
Old Aug 10, 2008 | 09:20 PM
glasstomb's Avatar
glasstomb
Cruising
Had the exact problem with my 90 vert. Ran fine when cold. Once it heated up the idle bounced around and there was a serious lack of power, it would stall and would not restart. Let it sit for an hour and it would start right up.
Diagnostics were clean. No codes. Turned out to be 3 bad injectors. Replaced all 8. Hot start problem gone, power is back and it idles much better.
Old Aug 11, 2008 | 12:10 PM
looney1316's Avatar
looney1316
just talked to the guy at fic he knows his stuff ordered new injectors i'll let you know how it turns out, will be here by the weekend so i can lock myself out in my lab and play--work that is(note to self pick up more beer in the event that lab work runs late)
Old Aug 11, 2008 | 08:08 PM
bizarroxxx's Avatar
bizarroxxx
TYeah thats right I will be there and you know I like beer
Old Aug 11, 2008 | 11:05 PM
looney1316's Avatar
looney1316
thanks
Old Aug 17, 2008 | 07:01 AM
looney1316's Avatar
looney1316
holy s**t we just put in injectors from fic what a change,it is like a new car,and so far it starts hot, to jon a fic thanks, great service,to B.XXX i would like to say thanks for helping me but i can't because i helped you.so thanks for coming over and bringing tools and letting me help you,great job
To will not start warm
