ASR Question
Old Aug 8, 2008 | 01:57 PM
bangand0lufsen's Avatar
bangand0lufsen
Default ASR Question
Just starting to get around to really fix the vert up as much as my income bracet will allow and noticed that when i hit my traction control button the light has never come on i just noticed there was a light the other day at a red light with the sun. I went in a parking lot the other day hit the traction control button and it never seemed to turn off at all like it used to. any ideas? 1993 Vert
Old Aug 9, 2008 | 04:45 AM
toptechx6's Avatar
toptechx6
The ASR Off, ASR active, and Service ASR lamps should all illuminate briefly when the key is first turned to the run position as a bulb check, if they do not I would start by checking the 5 amp cluster fuse. There are additional ABS/ASR fuses under the hood, consult your FSM for location. If all fuses are okay I would inspect the wiring to the EBTCM in the rear cargo compartment for corrosion, good luck.
