Why won't it start?
Old Aug 7, 2008 | 02:23 PM
shacky's Avatar
shacky
Default Why won't it start?
I have a '94 LT1 with 72k.
It has always fired right up when I turn the key and sounds like a million bucks. A few days ago, I started it, it ran for about a second and died and then I couldn't get it to restart. I turn the key and the starter turns the engine with lots of power, after doing that for about 15 seconds, I stop and try again. The first time this happened to me, it eventually started and ran without incident. Now, it won't start at all.
Here's a few facts that may or may not be relevant.
I put a new optispark in it about 2 years ago. It has about 4000 miles on it.
Before this happened, the gas got low and I noticed that the check engine light came on. I filled up with gas and I haven't seen the check engine light come back on.
I smell gas after have been turning it over for a while.
I am guessing I will have to have this towed into the shop, but I was wondering if any of the sharp minds here know the likely cause.
Thanks!
Old Aug 7, 2008 | 02:27 PM
All2kool's Avatar
All2kool
Fuel pressure is my best guess.
Old Aug 7, 2008 | 02:34 PM
shacky's Avatar
shacky
Would that mean fuel pump, fuel filter, or either?
Old Aug 7, 2008 | 06:10 PM
schrade's Avatar
schrade
Get the code[s]. Post back.
Old Aug 7, 2008 | 06:56 PM
ynk1121's Avatar
ynk1121
I wouldn't bring it to a shop yet. First check the code. Since the check engine light showed up you have a code stored. Then I would check for fuel pressure and spark.
Old Aug 7, 2008 | 08:16 PM
NEVRL8T's Avatar
NEVRL8T
Old Aug 7, 2008 | 09:20 PM
Road Agent's Avatar
Road Agent
Your local GM dealer should be able to help.
Old Aug 9, 2008 | 05:11 AM
86PACER's Avatar
86PACER
And bring a jar of vaseline just in case.
I would buy the GM shop manual and pull the codes from the car and take it from there.
To Why won't it start?
