Project CE~~Condenser
Old Aug 17, 2008 | 04:15 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default Project CE~~Condenser
Today I removed the radiator cover lid, yes it pain in the butt. The rad is busted and I have a Dewitt rad ordered but I found big foot's nest in there and the AC condenser is clogged with hair, dandruff, trash etc. I took everything out but there is much more in between. I did a search and Corvette Central has the condenser for $199.
I got advice on Dewitt and vette2vette.com. What advice can i get on condensers?
Old Aug 17, 2008 | 06:15 PM
aminnich's Avatar
aminnich
If it isn't leaking leave it alone, if it is go with new, not used.
Old Aug 17, 2008 | 08:14 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
With the radiator out of the way, you should have no problem cleaning the condenser. Spray some degreaser on both sides, let it soak for an hour or so and hose it off from behind so you don't get the front of the engine wet.
Old Aug 17, 2008 | 08:31 PM
rihwoods's Avatar
rihwoods
Pete..Clean it up and have it tested...I assume it is for R134...if not,then get a new one..(I'm still on R12 in my 78)...
Old Aug 17, 2008 | 08:34 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Thanks, I'll try that. I wish I had an UV light to ensure the sucker is not broken. Thanks
Old Aug 17, 2008 | 10:20 PM
tobijohn's Avatar
tobijohn
Bench Racer
What makes you think it might be broken (leaking)? Does the AC not blow cold?
Old Aug 17, 2008 | 10:39 PM
PLRX's Avatar
PLRX
2017 C4 of Year
You got it. This is what happens. The A/C control works but it's not at 100%. I press and it starts then lights start to blink and it goes off. The compressor clutch engages on and off. The blower only blows air (not cold) from the bottom. A CF member has experience with that so, once I get to work on the dash I'll contact him again.
I brought this up early because I wanted to know yout toughts and experience on this matter. That is why I took the pictures of the condenser.
Old Aug 18, 2008 | 09:03 AM
aminnich's Avatar
aminnich
OK, now that you said the AC is not working it mmakes me thinkk that the stains on the one side of the condenser are from a refrfigerant leak. If it feels oily then you have a leak. At the least you might want to have it tested.
Old Aug 18, 2008 | 01:40 PM
PLRX's Avatar
PLRX
2017 C4 of Year
If it feels oily
I knew it Thanks
To Project CE~~Condenser
