Mini Corvette Engine
Old Aug 18, 2008 | 09:24 AM
Chapindad's Avatar
Chapindad
Default Mini Corvette Engine
I thought I would share...
http://gizmodo.com/5037726/mini-corv...s-at-11000-rpm
Old Aug 18, 2008 | 10:14 AM
Calderone's Avatar
Calderone
nice i would like to see a copy of the L98
i found this on ebay not long ago
Old Aug 18, 2008 | 12:58 PM
Iroc57's Avatar
Iroc57
It is amazing what some people are able to do for if no other reason than to prove it can be done.
I am impressed
Old Aug 18, 2008 | 03:01 PM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Looks like he needs to adjust his alternator belt
Old Aug 18, 2008 | 04:23 PM
betyelou's Avatar
betyelou
Old Aug 18, 2008 | 04:28 PM
Calderone's Avatar
Calderone
hahaha i thought the same thing !
Old Aug 18, 2008 | 06:43 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I suppose this would be a "small block"
Old Aug 18, 2008 | 08:44 PM
NEVRL8T's Avatar
NEVRL8T
Wonder what it would sound like with a nice loping cam?
Old Aug 18, 2008 | 08:48 PM
CStewTAMU's Avatar
CStewTAMU
They said he made it "from scrach". I have always been fascinated with engine production. I am an accountant, and sometime I think I missed my call as a mechanical engineer.
How do you make something from scratch like that? How does he make such a precise instrument like an engine from scratch? Also, how many cylinders is that? How is it cooled?
Old Aug 18, 2008 | 08:51 PM
Mekanic's Avatar
Mekanic
I'd rather have a HEMI
Old Aug 19, 2008 | 02:12 AM
Eakster's Avatar
Eakster
Does he fill it up at a tiny gas pump?
Old Aug 19, 2008 | 02:02 PM
Klondike's Avatar
Klondike
Guys that can do that are like wizards of engineering and construction. I saw a tiny Ferrari once that everything worked. It had a V12 engine that ran, full functioning suspension with working hydraulic disk brakes...everything! I wonder what kind of oiling and cooling they have. The fact that they run at all blows my mind.
Old Aug 19, 2008 | 02:22 PM
chatham's Avatar
chatham
Default here is a link to a better article on it in the NY Times
http://www.nytimes.com/2007/06/24/au...rssnyt&emc=rss
Old Aug 19, 2008 | 02:35 PM
Fast Doc's Avatar
Fast Doc
Good old American ingenuity!
It appears to lack a cooling system. I wonder what the source of spark it. I see a distributor and wires, but no coil or battery. I wonder if it uses glow heads like a model car or airplane engine.
Old Aug 19, 2008 | 02:47 PM
tachout's Avatar
tachout
On that note, I just have to share this as well
http://www.nvbackflow.com/engines/
If you look around on this site you will find out that there are a few other guys that are into these small engines too.
Old Aug 19, 2008 | 03:43 PM
1985 Corvette's Avatar
1985 Corvette
More than likely he gathers all the specs/measurements of the original engine and divides it by the number he's planning to scale it down with. So if you had an engine with a 4 inch diameter bore and you wanted a 1/4 scale model of that engine, you would divide 4 by 4 and your model engine's bore diameter is 1. When it gets nitty gritty with lots of numbers past a decimal I'm not sure how he handles that part.
I believe bare minimum required to attempt a model engine besides understanding of math and precise measuring is a lathe and a machining mill. You can buy mini lathes and mills to fit in your garage but you'd probably spend a thousand or more for them. It requires patience as well, it's not something you can just dive into. Several mini engine builders I've spoken with stress making a single piston combustion or steam engine first to build experience.
www.cnczone.com
That link alone would keep you busy a year or longer learning.
Old Aug 19, 2008 | 11:23 PM
CStewTAMU's Avatar
CStewTAMU
Wow. That stuff is pretty neat.
But couldn't you just make your engine a lot easier by casting it? Seems like it would be a lot easier. I actually know a guy, a dental technition, that would probably know all that is needed to cast something VERY precise in metal.
Sure, after casting it, then you'd mill or machine it. The discovery channel has a show called ultimate factories. It showed how Ferrari takes scrap aluminum and casts it into the necessary parts. It's really not that complicated of a process.
They basically make the molds out of a sand mixed with some kind of resin or glue (after it hardens its VERY brittle and cracks apart pretty easily). Then they carefully fit the pieces of sand/resin mix together like a 3d jigsaw puzzle, pour in the molden aluminum and then just shake the sand/resin parts off. They are really brittle and crumble easily.
I think the hardest part would be making a crankshaft from scratch. Has to be super durable, perfectly balanced, incredibly precise (thousands of an inch or less in tollerance).
Old Aug 20, 2008 | 12:02 AM
1985 Corvette
That's the great thing about the pros: they make stuff look easy. You'd probably be better off machining a model engine block out of solid aluminum over making a resin cast for it. You have to take into consideration the resin molds are saving the negative space inside the block once the molten metal pours in.
There's people that actually melt their own aluminum and cast simple objects. Of course you'd need your own mini foundry to melt the aluminum. A poor man's method is lining a coffee can with a material that resists extreme heat. Coals are then placed inside the reinforced can and then on top of that sits the container that you drop your aluminum in that melts.
There's videos of it on youtube where people just take empty coke cans, put them inside their homemade furnace and it melts like butter.
To Mini Corvette Engine
