Do you shift your automatic?
Old Jan 6, 2002 | 01:19 AM
OrangeC4's Avatar
OrangeC4
Default Do you shift your automatic?
My friends think I am strange for shifting my vette which is an automatic when I race or do performance driving. I have been driving like this for a while now but, recently I got wondering how many other people shift their automatics. Since the only way I have of finding out is through here. How many of you shift your automatics?
Old Jan 6, 2002 | 01:41 AM
vader86's Avatar
vader86
Default Re: Do you shift your automatic? (OrangeC4)
i dont, let it shift by itself, it does it better than i would.
Old Jan 6, 2002 | 02:18 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
All the time. I have serious 6-speed envy.
Old Jan 6, 2002 | 02:37 AM
dmalhi1's Avatar
dmalhi1
umm......... i let it shift for me. the only time i shift it is when on the highway and i upshift it from Drive into Over Drive......
Old Jan 6, 2002 | 03:24 AM
Ezgoin721's Avatar
Ezgoin721
If I'm just driving around town, I usually let it shift itself...I'f I'm in serious mode, I always shift it manually!
Old Jan 6, 2002 | 03:33 AM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Shifting a auto will slow the Car down :yesnod: Just take it to the track and give it a try. :cheers:
Old Jan 6, 2002 | 04:53 AM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Default Re: Do you shift your automatic? (Zora)
depends on what I am doing mostly I just keep it in D because I drive so slow here :rolleyes:
Old Jan 6, 2002 | 07:16 AM
OcalaGuy's Avatar
OcalaGuy
Yes... from P to D
:lol:
Old Jan 6, 2002 | 09:41 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
I usually just let it shift itself. Sometimes i'll manually shift...but only when i'm "playing"...not serious. ;)
Old Jan 6, 2002 | 10:34 AM
SaveTheWave's Avatar
SaveTheWave
S. Indiana Events Coordinator
Cruise-In I Veteran
I spend a lot of time in 2nd gear when driving particularly curvy roads.
And here's a vid of what it sounds like :D
http://temp.corvetteforum.net/c4/sav...sgap_brian.mpg
[Modified by SaveTheWave, 8:40 AM 1/6/2002]
Old Jan 6, 2002 | 10:47 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Depends on what type of driving I'm doing.
Commute - keep it in D until the rare 55mph then OD
Hard Launch - D
Twistie turnie road with few straights - 2, occasionaly up shift to D and back down to 2. Depends on the length of straights. Keeps it in the power and tourqe band.
Jist my $0.02
Old Jan 6, 2002 | 11:33 AM
Snowblind's Avatar
Snowblind
Usually just leave it in OD and let it shift by itself.
If I am trying to show off, I sometimes put it in second. I like the sound and the instant response when I hit the gas pedal.
Old Jan 6, 2002 | 04:22 PM
GlockLT4's Avatar
GlockLT4
Default Re: Do you shift your automatic? (Ezgoin721)
It's usually best to let it shift since the computer knows when it should shift.. and you usually don't. I am going to be reprogramming my computer's shift points though so I won't have to worry about manually shifting for "sport mode". I'm going to extend shifts with over 50% throttle up into the higher rpm's.
Old Jan 6, 2002 | 04:38 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Do you shift your automatic? (Glock'94)
I just put it in OD and leave it. The only manual shifting ive done was down shifting to keep from riding the brakes on big hills or when the radar went nuts.
Old Jan 6, 2002 | 04:43 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
i let the car shift. i had a shift kit installed. now the car automatically chirps 2nd! :D my mechanic is always telling me i can shift the car manually but i just dont want 2 break anything. :smash: :eek:
Old Jan 6, 2002 | 05:12 PM
plastic thunder's Avatar
plastic thunder
No I just let it do it's thing :yesnod:
Old Jan 6, 2002 | 05:15 PM
J Z06's Avatar
J Z06
Default Re: Do you shift your automatic? (yoslambo1@cs.com)
To each their own.... some like to leave it in "D", some like to shift themselves. To control wheelspin on street tires I manually shift. On slicks... next time out, I am holding it down while leaving it in "D". Just for comparison, I'll do two runs in the same lane in "D" then run manually shift and see if there are differences. I'd always wanted to know if one's better than the other.
To Do you shift your automatic?
Old Jan 6, 2002 | 05:44 PM
MardiGrasMan's Avatar
MardiGrasMan
I never shift when going forward unless I'm on a steep incline in the mountains. :chevy
Old Jan 6, 2002 | 06:48 PM
OrangeC4's Avatar
OrangeC4
Default Re: Do you shift your automatic? (MardiGrasMan)
The tranny will up-shift at the right time most of the time, but what I have found is that it doesn't down-shift when you want it to and sometime it is too high of a gear. If you leave the car in D and you want to be in 2nd, like for going through s-turns and such it will up-shift when it doesn't like to be in 2nd anymore but when it should be. Times like this is when I shift it manually to get better performance out of the car.
Old Jan 6, 2002 | 06:56 PM
scorp508's Avatar
scorp508
From what I've seen manual shifting slows the car down at the strip. You have no control on how fast it shifts like a manual, so you are at the mercy of your tranny for how long it will or won't take depending on your setup.
If you have your cables adjusted right (or computer programmed right for later years), shouldn't it shift at optimal points anyways?
