TH700R4 - Reverse drum ...does not fit ?
Old Sep 14, 2008 | 02:13 PM
Calderone's Avatar
Calderone
Default TH700R4 - Reverse drum ...does not fit ?
Hi i purchased a brand new reverse drum for my TH700R4
and i find out that the piston that is supposed to go inside
does not fit the same way,its floating !!!!
The clearance circled in red is thicker...what's the problem ?
thanks
http://www.bulkpart.com/Merchant2/me...roduct_Count=1
ps : on the original drum it does fit very well
and it seems like extra space,this is the NO CHECK BALL version,the original has a check ball
OLD DRUM WITH PISTON
NEW DRUM WITH PISTON
Old Sep 21, 2008 | 12:06 PM
Pete K's Avatar
Pete K
I have been away for a week, but you probably know by now that the new drum needs the aluminum later model piston. Make sure to smack the restrictor orifice in the bleed hole.
