4+3 shifter question
Old Sep 19, 2008 | 08:18 PM
Vetteatlast's Avatar
Vetteatlast
Default 4+3 shifter question
I purchased an 86' coupe with a 4+3 trans about 7 months ago and it doesnt even have 30,000 miles on her yet. Its in great shape but I noticed alot of play in the shifter assembly , when I got it home I found that there is a shaft that holds the shifter in place and there are bushings on either end of the shaft .It looks like the bushings have wore into the fiberglass and have made the holes bigger and causing the shifter to wobble. does anyone have a breakdown or diagram of the shifter assembly so I can see what I can do to fix it ?? Any help would be great Thanks
Old Sep 19, 2008 | 09:43 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Shifter.pdf
Old Sep 19, 2008 | 10:44 PM
RedVette84's Avatar
RedVette84
Just never rip the boot on the trans that the linkage runs through. Near impossible to find one.
Old Sep 20, 2008 | 04:36 PM
Vetteatlast
Thanx, that helps alot
To 4+3 shifter question
