When replacing U- joints.......
Old Oct 2, 2008 | 03:20 PM
Bob89c4's Avatar
Bob89c4
Default When replacing U- joints.......
Doing the u-joints on my 89. Was making some strange noises from the rear, anyway followed the thread I found on here and got the rears off without many problems.On the drive shaft, do I have to loosen, move or take out the tranny support? It looks like there might be just enough room to squeeze it out. I have the rear exhaust out, the back cat on up still in. Will this stuff have to be yanked as well?
Thanks,
Old Oct 2, 2008 | 10:00 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
If you mean the C beam then yes it has to be moved out of the way. Take the four bolts out and just push it to one side and if I remember right the dif can be pushed back a little to remove the drive shaft. A little side note some oil will spill out of the trans when the drive shaft is removed.
Old Oct 2, 2008 | 11:29 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
I did not have to remove or loosen the C beam when I did the driveshaft u-joints this spring. I was able to work the driveshaft out and back in without issue.
Old Oct 3, 2008 | 06:39 AM
Bob89c4's Avatar
Bob89c4
I think I can slip it in and out but it sure looks like its gonna be a close fit. I knew if anybody would know you guys would. Gonna keep my fingers crossed and give it a try this weekend.
Old Oct 3, 2008 | 08:41 AM
Movnviolation's Avatar
Movnviolation
My 89 I did not have to take C beam out or loosen it. Looks tight but comes right out!
Old Oct 6, 2008 | 06:29 AM
Bob89c4's Avatar
Bob89c4
After cutting out about 3/16 strip of the seam/flange that is in the tranny tunnel next to the shaft, she popped right out! Should have her back and running tonight. Took the 71 out for a nice long drive yesterday and my left front brake caliper started leaking. Eventually only had emergency brake....which wasn't much to start with.
Crept home at about 15 mph. Now I know what my next project is.
Thanks for everyones input!
Old Oct 8, 2008 | 06:59 AM
Bob89c4's Avatar
Bob89c4
WOW got the 89 back on the road last night, did not think u-joints would make that big of a difference but WOW I sure can tell a big change in the cars handling.The spicers I took off did not look that bad. Put precisions(Usa) on it. Did not want to go with chinese ones from auto zone.
Thanks again to everyone for their help!
B
To When replacing U- joints.......
