Outer Door Seals ...???
Old Oct 10, 2008 | 09:36 PM
John88RedVette's Avatar
John88RedVette
Default Outer Door Seals ...???
Anyone ever change out your outer window door seals? I'm wondering what exactly is involved. Anyone have good detailed instructions? Two from MidAmerica are 59.99. Mine are not too bad, but could be better. Any help....Thanks in advance. JOHN
Old Oct 10, 2008 | 09:42 PM
Old87owner's Avatar
Old87owner
I would suggest getting the book 101 Projects For Your C4. It has a section on how to do it. I intend on doing mine sometime early next spring.
In the section, it tells you the tools you need, dissembly tips, reassembly tips, and other useful tips.
Old Oct 10, 2008 | 09:57 PM
C4boy's Avatar
C4boy
They are pretty easy to replace once you get the door panel off. You can get new, original GM seals here for the same price.
Old Oct 10, 2008 | 10:01 PM
John88RedVette
oh , inside door panel must come off? Figures...
Old Oct 10, 2008 | 10:36 PM
corvettedan22's Avatar
corvettedan22
Its easy. Take off door pannel, 3 pop rivets. I bought gm for $50 from a vendor on this site.
Old Oct 16, 2008 | 04:55 PM
blue88conv's Avatar
blue88conv
See this thread:
http://forums.corvetteforum.com/show...p?p=1565236620
Instructions can be found here:
http://www.corvettemagazine.com/2001...ndow/win-1.asp
Not too hard to do.
Old Oct 16, 2008 | 05:43 PM
TA's Avatar
TA
Not too bad of a job. I did inner and outer door seals earlier this year. The first door probably took a couple hours to get the process down. The other door, probably 30 mins for the whole process including removal/installation of door panel.
To Outer Door Seals ...???
