C4 front suspension leaf spring?
Old Oct 15, 2008 | 10:16 PM
CJWC4AZ's Avatar
CJWC4AZ
Default C4 front suspension leaf spring?
I should know this but I don't. Is there a leaf spring, single or otherwise, that is a component of the front suspension on our cars or is someone trying to make a few extra bucks at my expense?
Old Oct 15, 2008 | 10:18 PM
StealthLT4's Avatar
StealthLT4
Both front and rear springs are transverse composite leaf springs. Yes, they're leaf springs, but not exactly in the 'truck' sense. They run sideways on the car, from one wheel to the other side. Also, they are a single leaf of fiberglass instead of multiple steel leaves.
It's actually lighter than coil springs, which is why even the new Z06 and ZR1 use the same idea, composite leaf springs.
Old Oct 15, 2008 | 11:33 PM
Mojave's Avatar
Mojave
If you're checking to see if your leaf spring is still there, make sure you have plenty of blinker fluid and your muffler bearings are well greased.
Old Oct 15, 2008 | 11:50 PM
KitchenPass's Avatar
KitchenPass
While you're in there checking things, don't forget the piston return springs.
Old Oct 15, 2008 | 11:56 PM
CJWC4AZ's Avatar
CJWC4AZ
Default Many thanks
Thanx for all the positive(?) feedback people. I still love The Forum.
Old Oct 16, 2008 | 12:04 AM
pologreen1's Avatar
pologreen1
yes, and the reason people talk about them is, they have different spring rates. Some are real stiff rates and some are softer.
z51
z07
are the performance ones you can make your car perform better with . better mono leaf springs, and bigger sway bars, and lowering it.
To C4 front suspension leaf spring?
