Reliability items
Next summer we plan to take it to the Canadian Rockies for three weeks or so. Naturally I'm hoping for a trouble-free trip since Corvette specialists are few and far between there. Things DO wear out, but it's also possible to get a bum part when replacing things. Any suggestions on what items I should consider replacing now, even though they are OK (Opti??) versus just having the local Vette shop give it a good look-over and drive it as is?
I don't want to randomly replace things for no reason but also don't want to start walking half way through North Dakota or Manitoba!
Thanks!
If ya own a gun don't take it to Canada and the beer? Is at room tempature just like my ex's. Stop in to see Spearfish Canyon in South Dakota, it rips.
Underhood temperatures in a Vette can get hot, especially mountain driving. Coolant, Hoses, Brake Fluid (flush brakes and clutch), and oil should be in good condition. Always check your oil level, also on the road while gassing up etc.
How old are the tires? You may want to check if they are older than 10 years.
It is always a good idea for a Corvette specialist to look it over. I would start from their recommendation and check with maintenance history of the car.
C4ZF6nut
Thanks!
We drove our '96 out to Pennsylvania this summer, loved every minute of it. Hope you have a great trip!
Tires, breaks and wheel bearings.
Fluids; all. Check break, coolant, oil, transmission and power streering. Replace any that look funny. Check for leaks.
Be sure the battery is good. If you have any doubt, get it replaced.
All lights.
All of these are in the owners manual along with recommended service intervals.
One thing that will shut you down dead is the fuel pump. It is easy to replace. Be sure you have a spare or know where you can get one on the road. Some after market pumps come with poor quality hose and will fail due to hose rupture shortly after being installed. It's easy to fix but it's a pain in the a** to pull it twice to get going.
FYI - I've found the Corvettes to be very reliable and will get you home even if a lot of things are broken.
I'm not paranoid or afraid to drive it, just trying to do my homework now instead of with some moose looking over my shoulder!
I appreciate the input. My first two cars were Vettes, and two others after that, but I went 30+ years without, doing the kids and house thing. I must say it's tremendous having this site and the help of so much knowledge - "back then" you were pretty much reliant on the guys in the club and - if you were lucky - a local vette shop. Yes, it's mostly common sense stuff preparing for a trip but having input from those who have already dealt with the issues is good preventive medicine.
Some other things to consider which are among the most likely parts to leave you stranded are your tires, optispark, water pump, serpentine belt, battery, alternator, and starter.
