Another "How do I clean...." question
Whats the best way to get everything clean and shiny without damaging anything? I can cover the distributor but what about the Miniram and injectors? What products?
Thanks guys!
As you can see mine had an oil leak at some point of its 144,000 miles.
Under others suggestions, I had looked for Simple Green, but right next to it was a "Super Automotive Degreaser Orange Power Spray Blast"- it was a buck and a half cheaper, but it worked fast!
I took 1 old scrub sponge out of the kitchen sink, and scrubbed the bottom side of the car, frame, oil pan, tranny, etc... What a MESS!
Then I gently sprayed it off with the hose and whalla!
(Dont mind the exhaust- it's VINTAGE!
)Most say use simple green, dilute it, use a sponge and just be careful!
PS, Simple Green is also about the best hand cleaner I have ever used!
get a chance. I've used Gunk clear back in '65 on my GTOs and never
had any issues except the odor for a few days. That smell lets you know it's clean....HAHA
cleaner called USadvanage. The advantage is you can mix it depending
on what you have to clean. Strong for the engine block or weaker for
carpets/mats, garage floors etc.
Papa G
