Interior Lights Puzzler
Old Nov 25, 2008 | 08:50 PM
Redzoom's Avatar
Redzoom
Default Interior Lights Puzzler
OK, here's the deal. I have a '96 LT1 and yesterday evening the interior lights would not go out. I finally had to pull two fuses, one for the cargo lights, which also cut out the amplifer on the radio, and one for all other interior lights. Do you think it is one of the door switches, or maybe one of the door locks. Is there any way I could trouble shoot this to figure out what the offending switch is.
Old Nov 25, 2008 | 10:33 PM
Carguy2112's Avatar
Carguy2112
St. Jude Donor '14
I had that happen to me about a month ago. It turns out that the I didn't get the lock straight up and down when I took the key out of the door. I think if it's past 15-20* off, the lights never go out.
Old Nov 26, 2008 | 02:34 AM
Corvette505's Avatar
Corvette505
yup, lock has to be aligned right and oil your door switches, that solved my problem.
Old Nov 26, 2008 | 04:46 AM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
I also have a '96 LT1 and that happened to me before, turned out the switch that you use for the lights has an outside lever that when you sometimes turn on the lights, gets moved along with it. That may not be what it is, but you might want to check that first.
If its moved all the way to the top, there's your problem.
Laura
Old Nov 26, 2008 | 07:21 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Check the hatch switch as well. If a hatch vent was ever used on your car chances are the hatch switch is broke.
I had a hatch vent and had to replace the hatch switch three times. I don't use a hatch vent anymore.
Old Nov 26, 2008 | 10:18 AM
-=Tom=-'s Avatar
-=Tom=-
Laura
I had this happen to me in our minivan about a month ago that has a similar switch. I couldn't figure it out for the life of me and felt like a doofus when I finally did figure it out.
Old Nov 26, 2008 | 01:29 PM
Redzoom's Avatar
Redzoom
OK! Good input you-all. It isn't the dimmer lever or the hatch switch, BUT, it may be the door lock alignment. The problem started after I unlocked the passenger side, which I hardly ever do. I'm at home for lunch right now, but this evening I will fiddle with the locks to see if that does it. If anyone has any other ideas, let's hear them.
Old Nov 26, 2008 | 02:03 PM
ynk1121's Avatar
ynk1121
I'd guess the passenger side door ajar switch. I've had to replace mine twice over the years. Funny thing is the driver side sees all of the use and it's still original.
Old Nov 27, 2008 | 01:37 PM
Redzoom's Avatar
Redzoom
All right ! The lights work fine. I worked the door key locks a couple of times, put the fuses back in and viola! All is well. Thanks everyone.
Old Oct 31, 2020 | 04:31 PM
Abel Fuentes's Avatar
Abel Fuentes
1st Gear
That was the problem. Moved the outside lever down and the door lights turned off a few seconds after the door was shut. Thank you!
To Interior Lights Puzzler
