embarassing picture request re: SRC light code pulling
Old Dec 10, 2008 | 09:21 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Originally Posted by abc 123
Any other questions?
12 = Start of sequence
13 = Left rear time out
14 = Right Front time out
21 = Left Front time out
22 = Right Rear time out
31 = Left Front out of position
32 = Right Front out of position
33 = Left Rear out of position
34 = Right Rear out of position
23 = Loss of vehicle speed
41 = Selective ride control switch short to voltage
42 = Selective ride control switch open contacts
43 = selective ride control switch circuit open.
Gee just like FSM pg 3G-6 to 3G-14 in my 93 FSM Good to know
Old Dec 10, 2008 | 09:26 PM
abc 123's Avatar
abc 123
Surprised you didn't ask for what causes the codes. Or will you just gleam the knowledge from Hib when he posts his article.
Old Dec 10, 2008 | 09:37 PM
Redeasysport
Nah already know what causes the codes had an FX3 already. Been there done that got the T-shirt AND hat.
Old Dec 11, 2008 | 02:06 PM
BigTexas's Avatar
BigTexas
Yes, I have been misinformed but no big deal guys.
I shorted pins 3 to 4 (the CORRECT way BTW for a 95)
I got the following codes:
14 front right time out
21 front left time out
31 front left out of position
Now what does this mean? =) AKA: How do I fix these problems?
Old Dec 11, 2008 | 02:55 PM
Redeasysport
Pull the cap that has the motor in it and look inside it usually the gear gets broken.There is a clip that holds it on the shock. They are plasitc and fragile. What the system does on start up is rotate the shock left and right to check it.Try turning the ignition on with the caps off and see what the gear does and recheck for faults. If the shock is seized and cap ok you can get the shock rebuilt but it costs almost as much as buying a new one.
Actuator are~$200 or if this link still works you can get them fixed with a metal gear http://www.captainzcnc.com/
My fix was ty wrap the actuator back replace the shocks and remove the SRC bulb I did not think the cost was worth it for a DD
http://search.ebay.com/search/search...trypage=search
Old Dec 13, 2008 | 06:29 PM
BigTexas's Avatar
BigTexas
It looks like the gear inside the actuator is broken and it looks as though maybe the little gear on top of the shock (blue plastic?) is broken as well. I will try to post pictures later. (Have not checked right side yet)
Old Dec 14, 2008 | 12:42 AM
Redeasysport
Sounds like I figured you will find the gear on the other side is bad and mabey the shock OK or not. Do you feel like paying $600 to $800 to have it working? If not time to get some regular shocks.
Old Dec 16, 2008 | 09:02 PM
BigTexas's Avatar
BigTexas
Hell no I dont want to pay that much to have it working. I am a poor person...well middle class. How come my SRC light now flashes WHILE I AM DRIVING? After I pulled codes, my SRC light started flashing while I am driving. And yes, I have removed the paper clip.
Old Dec 17, 2008 | 11:16 AM
Redeasysport
Put the clip back in and and disconnect one side every 2 seconds for 3 times to reset the codes. No mention in FSM of a continuous flashin SRC light.
Old Dec 17, 2008 | 10:11 PM
BigTexas's Avatar
BigTexas
fixed...thanks. i guess i am going to look into not having this option for a while anyway. i guess i can always put it back. lol
Old Jan 28, 2009 | 11:16 PM
BigTexas's Avatar
BigTexas
Update! I am in the process of keeping the option. I am buying two shock gears from Captain Z, and I am going to get my actuators rebuilt for $125 a piece. Thanks for all of the help guys.
Old Jan 29, 2009 | 12:16 AM
Redeasysport
Glad to help. With CaptZ's metal gears it might last should have been that way from the factory.
Old Jan 29, 2009 | 10:55 PM
  #33
BigTexas's Avatar
BigTexas
I agree. I am getting new shock gears too because both of mine are broken. =( Should have been metal from the get-go.
