bose.
Old Dec 16, 2008 | 04:13 PM
93c4dad's Avatar
93c4dad
Default bose.
where is the amp located in a 92 convert.want to install new system.
Old Dec 16, 2008 | 04:24 PM
pcolt94's Avatar
pcolt94
Each speaker has its own amplifier board built into the speaker enclosure. They are driven by a low level signal from the actual tuner assembly installed behind the passenger in the storage box on the left side under the plastic box.
It all has to be replaced if a completely new radio system is installed.
Old Dec 16, 2008 | 05:53 PM
93c4dad's Avatar
93c4dad
Default rebose.
Yes i am replaceing all.i did look there but i didnot see it.what size is it.
Old Dec 16, 2008 | 06:10 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
The 90-92 amp/tuner is located in the dash under the glove box. (yeah, it's a bitch to get at). It is about 3in x 1in x 6 in. You may be able to get at it to unplug it without taking the dash pad out.
Old Dec 17, 2008 | 07:52 AM
93c4dad's Avatar
93c4dad
Default rebose amp
Thanks. i will look there
To bose.
