Need HELP
Old Dec 31, 2008 | 11:19 AM
randyduck's Avatar
randyduck
2nd Gear
Default Need HELP
OK new to this i need help with a 84 vette Bo here we go new fuel pump and relay still no fit to the pump but i can hoy wire it an make it run will the inertia switch have any thing to do with it it has been sitting for 8 years under a carport
Old Jan 1, 2009 | 02:47 AM
81c3's Avatar
81c3
With a car sitting for that , long, it could be a bunch of problems. Look over all the wiring for chewed wires from mice. If theres no fire to the pump, perhaps the ignition switch is faulty. Is it an automatic? Maybe the neutral safety switch. If its a standard, maybe the switch on the clutch pedal is bad. Give more info and try to slow down when you type so its a little easier to determine what you write. You can get better help that way!
Old Jan 1, 2009 | 08:39 AM
randyduck's Avatar
randyduck
2nd Gear
Thank you found the problem it was the ground wire
To Need HELP
