I am looking for the power door lock relay in an 89 coupe. Its not behind the information panel above the radio, and I didnt see it under the dash. Anyone know where it is????
umm.... maybe it ran away, joe ? ...... :lol: :jester
sorry sorry bad joke i got no clue where it is.... hmm you post this in the tech area yet?? i bet they can answer this.
I looked on my micofiche and couldn't find a relay. However, in the section there is a note that says " 1989 Central Control Module added for 89 to include several body and chassis electronic features previously using stand alone modules" Perhaps it was incorperated in there for your car. I don't know if this helps you or not.
JonM-Thanks for the info, that may be why I cant find it :lol: All I have is a Haynes manual for the car and all they show is the setup with a relay.
My door locks arent working, the solinoids are good, the switches are working, all the fuses are good, but no power goes to the solinoid. I'll have to track down this :reddevil module and check it out. Thanks
From: And on the fifth day, subpoenas were served to Obama senior staff
Re: Still cant find it... (Radio Joe)
No relay and not connected to CCM. It's a very simple circuit. Power from 30A circuit breaker in fuse block to both switches. Switches go directly to door lock motors. Only other thing in the circuit is the theft deterrent module to sence when doors are locked.
I'll have to cut into the loom in my doors. Mabee the wires are cut then?
I checked the circuit breaker, and the switches, and the door lock motors and everything is good. When I probe at the switch, everything works as it should, but when I check at the motors, no power. I'll have to get farther into it this week. Thanks for the info!
humm could be the door lock actuators, mine were frozen had to take them apart clean them up get ride of corrosion and then put them back in , good as new :yesnod:
