head lights
Old Apr 13, 2009 | 07:37 PM
blackbear bob's Avatar
blackbear bob
e mail sent
Bob
Old Jun 28, 2009 | 01:19 PM
jgilpin's Avatar
jgilpin
Cruising
This is where i'm at. I checked all the fuses and all are good. I replaced the actuator/motor. I replaced the actuator control module. Still the left head light will not raise or lower on its own as it is not getting power. ANY IDEAS OR SUGGESTIONS WOULD BE MUCH APPRECIATED.
Old Jun 28, 2009 | 04:08 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Just a quick question. Basically can't you swap inputs to the lights? This would verify headlight assembly inop. If it follows the light, then you have a bad light. If it doesn't then you can back track from there. Swap outputs at source to isolate further. I don't have my FSM with me at the moment but I will look when I get home. Sorry I can't be of more service.
Old Jul 1, 2009 | 04:45 PM
jgilpin's Avatar
jgilpin
Cruising
Do you mean remove the left actuator/motor from its housing and attach to the right side to test it?
I am thinking there is a break in the wiring somewhere. Is there any places that typically this has/may occur.
thanks
