85 Rims
Old Jan 20, 2009 | 12:13 PM
Pwnage1337's Avatar
Pwnage1337
Default 85 Rims
Just a few questions here.
Most aftermarket rims I see are for 88-96..why is this? Is there some kind of adapter you can buy that will allow for the use of these rims?
I am interested in some ZR1 rims
Thanks,
Jeremy
Old Jan 20, 2009 | 12:28 PM
vader86's Avatar
vader86
Because the offsets are different for 84-87, and the offset made for newer cars is larger, in general, so it doesnt make alot of sense for manuf. to make extra sets for a unique offset.
AFS does make rims that will bolt up without anything, in the correct offset.
You can buy an adapter plate to make 88-96 or other rims to fit. All this is in the FAQ.
Old Jan 20, 2009 | 03:45 PM
ZfidyONE-84's Avatar
ZfidyONE-84
i know you can order from mid america, and other corvette places the correct offset for the 84-87 corvettes
Old Jan 20, 2009 | 05:14 PM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
Talk to one of the sponsors to the left. TomZwheels should be able to help you.
Old Jan 20, 2009 | 06:44 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Try to avoid using spacers or adapters as some owners have had problems with them. The correct offset is 38mm. on your car.
Old Jan 20, 2009 | 06:53 PM
ThomasRetUSN's Avatar
ThomasRetUSN
I got my ZR1 wheels and tires for my 86 at:
www.lakeshorewheelandtire.com
Mounted, balanced and delivered for $1239. I have had them about 2 1/2 years with zero problems.
To 85 Rims
