Lost engine number
Old Jan 22, 2009 | 06:05 AM
ozcar's Avatar
ozcar
5th Gear
Default Lost engine number
Is there a register that keeps records of what my original engine number is? The import papers for my car into Australia only show the VIN. I didn't record my engine number and sent the block in for machining and now have no idea of what the engine number is.
Regards
Zak
Old Jan 22, 2009 | 07:41 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I think the engine number will be the last 5 or 6 numbers of your VIN followed by a suffix code based on the car's trans and whether it had an oil cooler. Also, cars for export all had the same suffix, ZJC.
Old Jan 23, 2009 | 02:05 AM
rodj's Avatar
rodj
The engine block is stamped something like
V1011 ZXX
being the factory and date code followed by engine code listed below
The last 7 digits of the VIN are stamped below that: such as 5103739
1985 engine codes are
ZDF: 350ci auto
ZJJ: 350ci auto, OC
ZJB: 350ci manual
ZJK: 350ci manual, OC
OC =oil cooler
As yours is not a "export " car , it will not have the ZJC code
Old Jan 23, 2009 | 05:37 AM
ozcar's Avatar
ozcar
5th Gear
Thank you very much.
Old Jan 23, 2009 | 10:42 AM
jrzvette's Avatar
jrzvette
V1011 ZXX
ZDF: 350ci auto
ZJJ: 350ci auto, OC
ZJB: 350ci manual
OC =oil cooler
Just out of curiosity what is considered an "expot" car. Last time I checked there is no New South Wales in the USA.
To Lost engine number
