Cooling Fan Question
Old Feb 17, 2009 | 11:45 AM
coco1950's Avatar
coco1950
Default Cooling Fan Question
I have a 89 Corvette L-98 which I am in the process of replacing the head gasket. The cause of the failure was the thermostat failed in the closed position and the engine overheated. When I pulled the radiator cover to do some work I noticed only one fan. The main fan on the engine side up against the radiator. The manual states that there supposed to be two. Do you think the previous owner had the second cooling fan removed. I can not find any wire connections so was the second fan an option in 89.
Any information on this would be appreiciated.
Old Feb 17, 2009 | 03:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Booster fan(front of condensor) was an option.
Old Feb 17, 2009 | 04:12 PM
coco1950's Avatar
coco1950
Thanks for your help !!
Old Feb 17, 2009 | 04:47 PM
rodj's Avatar
rodj
Originally Posted by coco1950
I can not find any wire connections so was the second fan an option in 89..
If the 2nd fan was factory fitted you should have a temp sensor between #1 +3 sparkplugs; if not there wil be a pipe plug with square head in the same location
Old Feb 17, 2009 | 08:59 PM
SunCr's Avatar
SunCr
Vette Trivia: Of the 26,412 produced for '89, 20,281 came with the Aux Fan Option. Interestingly, 607 more '89's (20,888) came with the Heavy Duty Cooling Package maybe meaning that a couple of Dealers realized that capacity, not the number of fans, promoted better cooling. Neither system, Heavy Duty or otherwise, grounded the Main Fan Relay at any temperature other than 226 degrees (a/c off) and neither system needed any more than that. As to your head gasket, a stuck thermostat may have led to a blow out, but the 113 headed Vettes had numerous instances of head gasket failure (which is how I found this Forum). GM traced the problem to misaligned intake gaskets which led to leaks, which led to galvanic corrosion, which then ate up the head gasket. The '91 L98 heads (and all current production 113's) are counterbored for gasket retainers which maintain better intake gasket alignment, but there have been a few '91's around here with the same failure. The problems allmost always developed at #7, a lot seem to have been under warranty (mine should have been), but if the leak remained for long enough, there will often be a groove worn into the deck of the block. You should be able to tell once you've got the heads off, but whatever fan or fans your Vette has probably has nothing to do with it. And if you find galvanic corrosion in your coolant passageways, I'd ditch the radiator for a new one, maybe the Heads (depending on severity) and also yank the Heater Core which is going to plug up if it hasn't allready. Then make sure you flush the Block by pulling the oil cooler hose at the oil filter (assuming you have that option) or the knock sensor.
Old Feb 17, 2009 | 10:25 PM
Iroc57's Avatar
Iroc57
Well...The OP did say ANY information would be appreciated
Old Feb 18, 2009 | 10:33 AM
coco1950's Avatar
coco1950
Thanks SunCr, alot of good information here about the 89 Vet. I will check it all out.
To Cooling Fan Question
