Torque spec
Old Feb 22, 2009 | 05:24 PM
efweber's Avatar
efweber
Default Torque spec
I have replaced the ball joint and bushings on my front upper control arm, but I can't find a torque spec anywhere for the two large nuts that hold the cross member to the A-arm. Any ideas out there?
Old Feb 22, 2009 | 06:32 PM
engle1147's Avatar
engle1147
If your talking about the 2 large nuts on either end of the cross arm that go against the rubber/poly bushings for the upper "A" arms......there are no torques specs listed in the FSM for these. I recommend a torque setting of "good and tight".....I did mine a # of years ago with the same G&T torque and they have been fine.
Old Feb 23, 2009 | 05:43 AM
toptechx6's Avatar
toptechx6
If you are talking about the nuts that tighten against the alignment shims, my 93 books indicates 37 ft. lbs.
To Torque spec
