chip repair
Old Feb 25, 2009 | 05:13 PM
electricfish's Avatar
electricfish
Default chip repair
Has anyone used Langka products or other "systems" for rock chip repair, if so, recommendations would be appreciated.
Thanks, efish
Old Feb 25, 2009 | 06:45 PM
Paul Workman's Avatar
Paul Workman
Default Langka = OK IMO
Thanks, efish
I have used the Langka kit successfully a number of times now, on a black and now a red Vette.
The trick is...temperature and time: Attempt to "sand" the blob too soon, and it will divot. Conversely, let it dry too long, and you are gonna need a buncha elbow grease to get it flat!
At 70º and low to moderate humidity, I wanna say it takes about 90 minutes for a small blob to be ready to "sand". But, temp and humidity will affect it. So, what I do is wait till I have a few rock chips and "blob" them all. Then I give 'em about an hour and try one. If it is too early, then I wait a little and try another. Again, if it divots then wait another 30 minutes and so on until your have the time/temp conditions for your situation identified. Then have at the rest of them - spacing out the paint blobing so as you finish one the next will be "just right".
Some trial and error, to be sure. But, when I got the timing/temp combo right, it turned out beautiful - dare I say "perfect"! (I couldn't see where the chips were, and I knew where to look too!
Your mileage may vary.
P.
Old Feb 25, 2009 | 06:49 PM
stick105's Avatar
stick105
used it on my Black 84 with a fresh paint job and was overly impressed with the outcome. Since then I use it on all my familys cars. It works verry well, just follow the directions.
To chip repair
