Emblem Insert??
Old Mar 6, 2009 | 03:27 PM
Brett Richmond's Avatar
Brett Richmond
Default Emblem Insert??
What is the best way to get one of the inserts out of the emblem itself without breaking it?? I want to do a little project but need to get one of them out without breaking the emblem frame. Any ideas would be appreciated.
Old Mar 7, 2009 | 12:02 AM
Snakecharmer383's Avatar
Snakecharmer383
My rear just popped out. I currently trying to think of something to do with it. Which one you talking about? What's your idea?
Old Mar 7, 2009 | 06:47 AM
Goldcylon's Avatar
Goldcylon
Once the two bolts are removed all thats left is the adhesive backing. I had a lot of luck with some weadwacker nylon line and just wiggled back and forth with the line along the emblem in a sawing motion like a piece of dental floss. Wont hurt the paint and its a lot safer than a screwdriver trying to pry up the emblem. Then the 3M adhesive remover took care of the Adhesive left behind. Goo Gone will work in a pinch as well.
Old Mar 7, 2009 | 08:55 AM
engle1147's Avatar
engle1147
I've picked up and messed with a few "used" emblems over the years....if your lucky the inserts might pop out...the backs of the inserts are sometype of a foil like material which can tear when removed which renders the insert worthless. If your looking to clean up your emblems just tape over the inserts with masking tape and refinish/surface the rest of the emblem. If you want extra emblems with faded inserts....let me know I have a few laying around I can sell you for cheap.
Old Mar 7, 2009 | 02:59 PM
Brett Richmond
I am
Old Mar 7, 2009 | 05:53 PM
pologreen1's Avatar
pologreen1
cool
To Emblem Insert??
