broken plastic
Old Mar 8, 2009 | 11:02 PM
Elrick's Avatar
Elrick
Default broken plastic
I am swapping out the interior in my 86 and finding that the majority of the plastic tabs on the bezel plates and console covers are all cracked or broken. Many of them can no longer hold screws. What have people done to deal with this without buying new covers. I am hoping this will also cut down some of the rattles I hear, if I can screw everything down like it is supposed to be. Thanks guys
Old Mar 9, 2009 | 12:07 AM
engle1147's Avatar
engle1147
If the pieces are only cracked and not broken off get some good quality plastic epoxy and apply it over the cracked areas on the backside of the bezel. Do not twist, bent, pry, or over tighten the screws when remounting bezels.
Old Mar 9, 2009 | 01:12 AM
dan6712cc's Avatar
dan6712cc
If its made out of ABS you can try putting ABS shavings in a squeeze type container like a mustard container then mixing it with MEK or Acetone until it makes a paste. Apply this to the problem areas and it will be as strong as the original. This is what a lot of people use to make custom interior pieces, especially for where the CD player goes.
Old Mar 9, 2009 | 06:30 AM
pianoguy's Avatar
pianoguy
http://plastex.home.att.net/
Old Mar 9, 2009 | 07:18 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 9, 2009 | 07:46 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default abs
Thanks for the tip.
Corvette Mike
Old Mar 9, 2009 | 12:05 PM
molested84's Avatar
molested84
Originally Posted by CorvetteMike2004
Thanks for the tip.
Corvette Mike
Very cool tip.
I wish I hadn't skipped that chemistry class in school.
To broken plastic
