Timing Adjustments - Need Help
Old Mar 17, 2009 | 12:46 PM
Corvette505's Avatar
Corvette505
Default Timing Adjustments - Need Help
Seems like if i set my timing around 6/8 BTDC than it will accelerate no problem, but the idle after warming up is a bit up and down. Now if i turn the distributor clockwise it lowers my timing, get a nice idle, but when i "punch" the gas i get a little hesitation, which just drives me nuts. Any suggestions????
Old Mar 17, 2009 | 12:48 PM
Corvette505
It's a 1990 Coupe
Old Mar 17, 2009 | 12:49 PM
floridamale's Avatar
floridamale
Set the timing to the right spot, then you might try cleaning your IAC valve.
Old Mar 17, 2009 | 11:04 PM
Calderone's Avatar
Calderone
remember to disconnect the tan line / black cable before adjusting it !
then connect it again.-
Old Mar 18, 2009 | 07:58 AM
Iroc57's Avatar
Iroc57
Set your timing at 8 and find your idle problem.
Old Mar 18, 2009 | 09:55 AM
Muffin's Avatar
Muffin
BINGO. If the ESC is not disabled base timing will not be correct.
Old Mar 18, 2009 | 10:01 AM
Calderone's Avatar
Calderone
Base timing has to be 8 ? i forgot it
Old Mar 18, 2009 | 10:21 AM
floridamale
You have posted this in both General & Tech it's easier to follow if in just one section. A idle that is hunting & timing are 2 different issues. Set base timing, then deal with the idle condition. If you search on here you will find having a dirty IAC & Throttle Body is one of the # 1 cause’s of a hunting idle condition. Cleaning usually takes care of this, you might also want to set your throttle position sensor should be between .42 & .62 volts
Old Mar 18, 2009 | 03:38 PM
Iroc57's Avatar
Iroc57
6 is factory I believe for most but 8 works and give a little better response. Some have done 10 but I remember reading that they had detonation issues.
Old Mar 18, 2009 | 03:48 PM
pologreen1's Avatar
pologreen1
10 sounds
Old Mar 19, 2009 | 01:02 AM
Corvette505
ok, i will try setting it back to 6/8 and dealing with the IAC, TPS, etc
Thanks all
Old Mar 22, 2009 | 09:39 PM
Calderone's Avatar
Calderone
what happened ?
did you solve it ?
Old Mar 22, 2009 | 11:41 PM
Corvette505
reset my timing, put in a new iac, still have idle issue.....tested the fuel injectors The injectors had many different readings, one was as low a 2.3, others were as high as 17. Funny thing was, when i pulled the elec connector off the bad ones, the idle adjusted just fine. Does this mean the injector truly is bad and I should replace them (i'm not one to replace just one, if im going to do it i'd rather replace them all so they are all consistent with how new they are and same brand etc) or does that mean the problem lies elsewhere?
To Timing Adjustments - Need Help
