SeaFoam - How Often?
Old Mar 17, 2009 | 01:38 PM
All2kool's Avatar
All2kool
Default SeaFoam - How Often?
How often should a person put a can of SeaFoam through the fuel system? Can it be used too often?
Old Mar 17, 2009 | 02:46 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Every other oil change would be more than enough so it would just be throwing money away. 1/3 in your brake booster line, 1/3 in your oil, and 1/3 in your gas tank. Let it run through the system and promptly change your oil/filter. I don't know of any negative effects other than it being close to ten dollars a can...Maybe every 10,000 miles or once a year?
Old Mar 17, 2009 | 02:56 PM
runner140*'s Avatar
runner140*
Thats what the instructions on the can says. I wouldn't put that in my oil. I use half a can in the brake booster vacuum line and half in the gas tank. I use a can every 15,000 miles.
Old Mar 18, 2009 | 10:23 AM
All2kool's Avatar
All2kool
Originally Posted by joshwilson3
I did the seafoam for the first time on my 89. 1/2 in the brake booster line. Lots of smoke.
Educate me on where to put SeaFoam in the Brake Booster (on an L98) and how it is helpful.
Old Mar 20, 2009 | 11:32 AM
IAIA's Avatar
IAIA
What should I do if, when I turn it off and try to drown it, the engine stays on and starts dieseling and shuddering. That happened last time I used SeaFoam, so I quickly restarted it for half a minute, then it shut off. But then, I think I lost the "final coverage" of pouring it in while shutting it down.
Old Mar 20, 2009 | 11:48 AM
M.J.L.'s Avatar
M.J.L.
The hose that goes to the brake booster needs to be removed from the brake booster only! That is a vacum line which leads to the top of your motor internals. While having someone holding the car at 2000 RPMs, slowly pour it thru the line until the motor stalls(About half a can)j. Let it sit for 15-20 minutes. Then start it up. If it was full of carbon deposits, then you will have a large smoke show. That is the carbon being burned out. The smoke should only becoming out of the tailpipes though.
If you put it thru your oil, change your oil afterwards. Don't wait. I would estimate 20 miles would be OK to drive with sea foamed oil but I personally, change it before the car moves. Just my expereince with it. I have poured it thru the brake booster(vacum line), oil, and gas tank. It does run a little smoother and some smoke did come out. Last tip, be careful not to pour to much sea foam to fast thru the vacum line because you risk hydrolocking your motor.
Old Mar 20, 2009 | 11:50 AM
M.J.L.'s Avatar
M.J.L.
I am deeply confused with your post. Keep the car at 2000 RPMs and SLOWLY pour it thru the vacum line. It should stall. Let it sit for 15 minutes then restart it. You shouldn't try to "drown it" or pour it in while your "shutting it down". If you cut the car off then poured seafoam in it, that was incorrect. Could you explain your problem in more detail?
Old Mar 20, 2009 | 11:51 AM
M.J.L.'s Avatar
M.J.L.
Why would you not use it in the oil? I have with no ill effects. I am curious as to why you say no.
Old Mar 20, 2009 | 12:04 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Old Mar 20, 2009 | 12:24 PM
IAIA's Avatar
IAIA
There are so many posts in here about SeaFoam. Some say let it sit 15-20 minutes; some say let it sit overnight. Some say put in 1/3 can, some say put in a full can. When mine was dieseling, it was based on recommendations I read that said, as it stalls, turn off the ignition, and put in that last bit quickly right at the end." My engine really didn't stall out...even before "that last bit."
Thanks for the help. I'm about to put it in while at work my smoke show is away from the house.
Old Mar 20, 2009 | 12:36 PM
Demonic85's Avatar
Demonic85
I found it easier to suck it in via the PCV hose on the passenger side, then let it sit for an hour.
Old Mar 20, 2009 | 01:00 PM
M.J.L.'s Avatar
M.J.L.
My car did not stall either. I shut it off once I put half a can thru there. I did not want to bring in my *personal* experience. I was just relaying the proper information and techniques out on the board. Don't let it sit overnight. 15-20 minutes is fine. It's only going to get so clean no matter how long it sits. Overnight is just way to long IMHO. Stick to the instructions on the can and everything should go smoothly. Some people think that instructions are for geeks to read.
Old Mar 20, 2009 | 01:13 PM
aklim's Avatar
aklim
I fill up the tank before I put it away and dump 2 cans of the stuff in it. Other than that, I don't use it. I have little faith in these "cleaner in a can" things. I believe in taking the injectors out at a certain interval and having them tested and cleaned.
Old Mar 20, 2009 | 01:20 PM
xsalvioutlawx's Avatar
xsalvioutlawx
I've been wanting to use sea foam in my fuel tank for awhile, but i'm scared of how much smoke there will be.
Is it THAT smokey? I don't want people to call the fire department on me.
Old Mar 20, 2009 | 01:21 PM
Demonic85's Avatar
Demonic85
oh yeah it smokes a LOT. just put ur car in plain view so everyone knows where its coming from.
Old Mar 20, 2009 | 01:36 PM
pologreen1's Avatar
pologreen1
The fire chief lives a couple houses down from me, he would go
Old Mar 20, 2009 | 01:46 PM
All2kool's Avatar
All2kool
Can someone post a picture of the Brake Booster Line (L98) one should utilize?
To SeaFoam - How Often?
Old Mar 20, 2009 | 02:01 PM
aklim's Avatar
aklim
Your brake booster should have a line going to the manifold if that is what you are trying to do.
Old Mar 20, 2009 | 02:07 PM
M.J.L.'s Avatar
M.J.L.
It's the black hose on the brake booster on the drivers side. Put your hand on the brake booster. See that thick tube? It's a vacum line. Remove it from the brake booster and pour it in thru that to clean "Sticky lifters, caked up gunk, ect"
Old Mar 20, 2009 | 02:09 PM
aklim's Avatar
aklim
I don't follow. That leads to the manifold. So, if you think it cleans gunk on the valves, fair enough. How does it do lifters unless you toss it in the oil??
