Coolant Low Light
Old Mar 18, 2009 | 09:13 AM
KBRVETTE93's Avatar
KBRVETTE93
Default Coolant Low Light
The Coolant low light comes on, as the car is warming up, then goes off. I've added coolant and actually am getting some release of coolant through the overflow.
Has anyone else had this experience? Would flushing the radiator be a good idea? 45K miles
Old Mar 18, 2009 | 02:21 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Have you checked the continuity on your low coolant sensor? When they go bad, they often cause the Low Coolant Lamp to illuminate intermittently on your DIC. Not expensive to replace, either.
Old Mar 18, 2009 | 04:00 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you might have a air bubble in the system.
Old Mar 18, 2009 | 07:50 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
My vette does that. As the water gets hot it expands and fills the radiator. I think the sensor is just below the cap.
JMO............as long as its not leakin and running hot its probably ok.
Corvette Mike
Old Mar 18, 2009 | 07:53 PM
Nowhere Man
Corvette Mike
the sensor is on the bottom of the surge tank where the cap is. you have to buy the whole tank to replace the sensor. its about a half hour job.
Old Mar 18, 2009 | 08:18 PM
engle1147's Avatar
engle1147
Old Mar 18, 2009 | 11:21 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Have you burped the cooling system per the owner's manual?
Old Mar 19, 2009 | 07:46 AM
KBRVETTE93's Avatar
KBRVETTE93
No
I guess I need to get a manual. Does anyone know the proceedure?
Old Mar 19, 2009 | 10:38 AM
Joevette86's Avatar
Joevette86
I had the same problem in my '86 a couple years ago. I flushed out the radiator and changed the coolant sensor. Have not seen that warning since. I believed it was the sensor but the radiator needed a flush anyway, so what the hell.
Old Mar 19, 2009 | 10:55 AM
engle1147's Avatar
engle1147
The low coolant sensor consists of 2 metal tabs that protrude into the radiator...nothin' to go bad in there. Clean the wire connector that hooks to the sensor outside the radiator and ensure that you have properly filled burped the system.
Old Mar 19, 2009 | 01:03 PM
KBRVETTE93's Avatar
KBRVETTE93
Thanks guys!
Old Mar 19, 2009 | 11:44 PM
jrzvette's Avatar
jrzvette
No
Go to this site:
http://www.corvetteactioncenter.com/...-links-c4.html
Old Mar 30, 2009 | 05:14 AM
samsonb's Avatar
samsonb
How do you get the wire off? I notice there are two clips, one of mine is broken. But I still can't get the wire off to clean it.
To Coolant Low Light
