89 Automatic shift indicator plate
Old Mar 21, 2009 | 10:21 PM
Redvette_22's Avatar
Redvette_22
Default 89 Automatic shift indicator plate
I just picked up an 89 coupe and it seems that the shift indicator plate (P-R-N-OD-D-3-2-1) does not seem to fit the hole in the console plate. The opening of the console plate is approx. 6 3/4" and the clear indicator plate is approx. 6 3/8", so there is a space at the back. When I took it apart to fix the indicator needle, I noticed the tabs at the front and back did not even fit into the holes in the black lower panel (the black panel that the indicator needle rides on) and one tab was broken off and even if it was not, it would not fit the holes cut out for them. Is there a different console plate for the 84-89 C-4's and maybe somebody replaced mine with an incorrect style??
Old Mar 21, 2009 | 10:34 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
If its like my mine, its due to shrinkage with age. I bought my car new and it fit. 20 years later I have about a 1/2 inch gap. I have never been able to find that part in a repo or oem also.
Old Mar 21, 2009 | 10:49 PM
Redvette_22
If it is shrinkage, and this happens to the "older" C-4's, it's hard to believe nobody makes a replacement part?
Old Mar 21, 2009 | 10:52 PM
CorvetteMike2024
Corvette Enthusiast
Default vette
Good luck. Let me know if you find one. I need one too.
Old Mar 22, 2009 | 01:40 AM
engle1147's Avatar
engle1147
Mine has a 1/8" gap on the front and back....now. I've had a few drinks tonight but I don't think my '89 auto has a 3 as in "P-R-N-OD-D-3-2-1"
Old Mar 22, 2009 | 10:48 AM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Old Mar 22, 2009 | 11:20 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old Mar 22, 2009 | 11:26 AM
pologreen1's Avatar
pologreen1
Originally Posted by Vette73
you read my mind
To 89 Automatic shift indicator plate
