changing out a headlight
Old Mar 23, 2009 | 08:14 AM
ric6312's Avatar
ric6312
Default changing out a headlight
what is the best way to change out a headlight on a 86, does the plastic cover nee to be removed, does the headlight need to be in the out postion or can i change it from under the hood. thanks
Old Mar 23, 2009 | 11:59 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
This is what my manual said to do. Open the hood and open the light assembly, by hand, about half way open. Then you have to take off the headlight bezel. Then I closed the light manually again and then opened the light up with the motor and then you can unscrew the light. It's been a while since I changed it but I believe that's what I did.
Old Mar 23, 2009 | 12:05 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
RTFM.
Old Mar 23, 2009 | 12:37 PM
chuck13's Avatar
chuck13
good answer
Old Mar 23, 2009 | 01:01 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
C'mon, help the noob out. The search function ain't as great as it used to be.
Okay,
1. Open the hood.
2. Pull the **** to turn on the light, time it so that the light rotates HALF way open or just about half way then stop pulling the ****. Keep the **** IN half way to keep the lights off but the light assembly in good position. You may have to give it a few tries to time it perfect. The point is to have it in good position but not have the lights ON.
3. Go to the front of the car and take off the two screws next to the light bezel. The screws are on the side, horzontally.
4. Go back to the underside of hood and take off the two screws remaining that keeps the bezel on. If you rotated the light assembly correctly, you will see the two screws on each tab up top.
5. Remove the 4 (but sometimes 2 or three) screws that holds up the thin metal bracket that keeps the light bulb from falling out.
6. Gently let the bulb hang loose, reach behind it and disconnect the plugs
7. Replace with new bulb. Reverse the steps to completion.
8. When you have time at night, check the alignment. The notch up top and to the side indicates where to stick the philips screwdriver in to adjust the angles.
Old Mar 23, 2009 | 01:57 PM
RetiredSFC 97
Okay,
1. Open the hood.
Yes. what he said. But I turned the light manually instead of screwing with turning the light on and off.
To changing out a headlight
