C4 Headlights
Old Mar 23, 2009 | 08:24 PM
dechilders's Avatar
dechilders
Default C4 Headlights
I've searched and got a hit on everything but what I need. I can't figure out how to get the headlight bezel off my 95 to change the headlight. I got the two upper screws out of the bezel but the end that meets the outside cover doesn't come loose. If I yank it something will break. Can anyone guide a lost soul? Thanks.
Old Mar 23, 2009 | 08:46 PM
StealthLT4's Avatar
StealthLT4
Did you remove the cover? There are 4 screws total, 2 Torx and 2 Philips, that hold the cover on. You have to manually raise the headlight 1/2 way to be able to access them all at the same time. Then there are just 4 Philips screws that hold the silver headlight trim piece thingy on, which sandwiches the headlight in place. Remove those 4 screws and that piece comes off, along with the headlight.
I'm kind of confused as to what you're referring to with 'bezel' and 'two upper screws,' but hopefully this helps.
Old Mar 23, 2009 | 08:54 PM
dechilders's Avatar
dechilders
Default Thanks
I couldn't see the side screws until I found a brighter light. Getting old is hell. Anyway, thanks for the help I now have a new headlight installed.
Old Mar 23, 2009 | 09:24 PM
ZfidyONE-84's Avatar
ZfidyONE-84
to get to them, rotate the headlights half way... turn on the lights like normal, but when they get half way around, turn it to the parking lights, and it will halt the lights
To C4 Headlights
