88 TPI vacuum problems
Maybe you guys can help me out. I put some pictures here. Maybe you notice something whats wrong with my L98 vacuum lines. When I fired it up it rumbled when idling, but I think its because timing isn't right.
Removed my thread to Tech/Perf. section
The line from the fuel pressure regulator should run to the next fitting over where you currently have it connected. (closer to the front of the motor).
Not sure where the origination of the other vac line is that you will now have to find a home for (it almost looks like the EGR connection...but I can see the EGR is hooked up)
Hope that helps and doesn't make things worse.
That check valve tee in first pic, belongs at the back of motor. The IN side of check valve is fed from a line going to nipple on pass side plenum. The two outs from check valve go to vacuum storage tank line( and cruise if you have it) and HVAC line coming out of large wire harness, at back of motor.
The second vacuum port on pass side plenum, goes to a "Y" , one side of "Y" to fuel reg, the other to A.I.R. solenoids beside AC compressor.
Small nipple under TB goes to EGR solenoid beside thermo housing.
