What do you call these???
Old Apr 12, 2009 | 08:34 PM
LannyL81's Avatar
LannyL81
Default What do you call these???
Looking for the oblong plastic insert that is sloted and expands when a screw is screwed into it.
Particluar ones are the ones behind the door panels where the lock, door handle, light trim panel goes. There are three of these plastic oblong things that go into the metal. I do not know what these things are called nor where to find some.
Anyone?
Old Apr 12, 2009 | 08:50 PM
engle1147's Avatar
engle1147
Screw Retaining Nut:
http://www.ecklers.com/product.asp?p...8&dept_id=1690
Old Apr 14, 2009 | 02:12 PM
LannyL81's Avatar
LannyL81
After more searching I think I found these to be GM 1377030 or Au-ve-co 10365. Both call them a bar grommet. Found them on the 'Net for $7.28 for a 100 of them, slightly more than I need, but guess I will have plenty of spares on-hand.
Old Apr 14, 2009 | 02:24 PM
aminnich's Avatar
aminnich
Look in the 'help' section at your local auto parts store. I have heard them called 'bathtub anchors' in the past.
The only place I have seen them is in the rocker panel mounts on my vette.
Old Apr 14, 2009 | 07:14 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Wife calls that a "thingy". I have used a drywall anchor, cut off for a shallow grip.
Old Apr 14, 2009 | 07:26 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Carolina Houdaille
I found these at this place for 35 cents each. Check it out.
Carolina Houdaille
1914 W. Morehead Street
Charlotte, NC 28280
704.333-6669
Note:
Corvette parts
fasteners, clips, screws and top parts
To What do you call these???
