Passing Texas Emissions Help
Old Apr 25, 2009 | 06:59 AM
74Mako's Avatar
74Mako
Default Passing Texas Emissions Help
How do you get the koxs (parts/mil) down enough to pass emissions. My wife has a 91' vert with the factory TPI with a free flow borla on it. I removed the pre-cat y-pipe when I installed it and installed the by-pass sensor to make the fan come on @185 deg. Now it doesn't run hot but (also new alum. rad.) but for some reason will not pass emissions. Anyone have an idea or what I can do to check the problem ?
Old Apr 25, 2009 | 07:34 AM
larry00's Avatar
larry00
You can try some of the octane boosters from the auto parts.
I hear they work to somewhat clean up marginal readings.
The cats have to work [ chemical processes ] .
My Hot Rod had to be registered at my brothers place [ where it stays most of the time anyway ] to get around the tailpipe tasting inspection.
There should be an exemption for cars driven less than 3,000 miles a year.
A car not pollution inspected can only be operated in a pollution controlled county ten days a month.
No latitude for the car enthusiast these days.
Old Apr 25, 2009 | 09:04 AM
Thomas6614's Avatar
Thomas6614
If it still has the main cat, no reason it should fail. My understanding, the pre-cats only function to clean up exhaust when the car is cold. Before you take it for the test, be sure to have a long highway drive.
I had problems due to high HC and CO (2 of my injectors were bad - replaced all 8). Do a search for Harris County and you should pick up my post.
I believe you mean NOx?
I changed out my O2, ECM, EGR, vacuum lines and all injectors (Bosch III) and went from a garage stinking/failing emissions to being told by the inspection shop it was an exceptionally clean '89. (<$500)
Old Apr 25, 2009 | 09:06 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Make sure your EGR system is working, Vacuum, solenoid, etc. That's the purpose of it, to lower NOx caused by lean burn engines. As stated above, weak/dirty injectors can be a problem. Normally I'm against it, but if you are close, alcohol (less than 5%) or those pass emissions products (mostly alcohol) might put you over the top, or more correctly under the limit.
Old Apr 25, 2009 | 12:05 PM
shbbykins's Avatar
shbbykins
midland/odessa doesnt do pipe tests iirc. If your in the military then that whole emissionless registered car in emission county goes out the window
Old Apr 25, 2009 | 01:01 PM
1Harley 1Vette's Avatar
1Harley 1Vette
This is a very minor fix but I have passed with marginal readings after running a bottle of RXP through the tank. After that fill up and change the engine oil. Just a very small non technical answer. Sorry
Old Apr 26, 2009 | 06:19 AM
74Mako's Avatar
74Mako
Thanks but I have done all of the above,All sensors,egr are new.It is my belief that because I cooled down the original system and put the Free-flow Borla on that the cat is not getting hot enough to bring down the knox. The only way it will pass is by (1) putting the original pre-cat y-pipe back on or (2) totally replacing the free-flow cat with a more restrictive cat. It is a 91' and hence is still under current laws in Harris (Houston)and surrounding counties.It has to be 25 years old to qualify as an Antique. I also have a 74 and do not have to mess with this problem. Thanks everyone for the help.
Old Apr 26, 2009 | 07:20 AM
jeffp1167's Avatar
jeffp1167
use a vacumn pump and open the egr and see if the motor dies, if it doesn't probably plugged egr passages causing the problem.
To Passing Texas Emissions Help
