Jack Stands
Old Apr 27, 2009 | 09:22 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Jack Stands
I am considering purchasing a set of jack stands from Harbor Freight Tools. I am considering the 3 ton or the 6 ton stands. I was wondering if any one has used these or know of anyone who has? Would appreciate any comments or suggestions. Thanks.
Old Apr 27, 2009 | 09:30 PM
StealthLT4's Avatar
StealthLT4
No direct experience, but I use the cheapo 2-ton ones from Advance Auto all the time. I've seen the stands that HF sells and they look pretty similar. They've worked fine for me.
Old Apr 27, 2009 | 10:40 PM
96polovette's Avatar
96polovette
The lower capacity ones are lower when fully retracted and easier to fit under your low C4. Plus each corner will only need to hold 800-900 pounds of weight, 2 ton capacity is more than enough for a C4.
Old Apr 27, 2009 | 11:03 PM
yaknow's Avatar
yaknow
I personally use 2 ton stands because I had to lift the car too high to fit the 3 ton stands under the car
Old Apr 27, 2009 | 11:22 PM
realsass's Avatar
realsass
I think you will be happy with the 2 tons!
Old Apr 27, 2009 | 11:24 PM
rodj's Avatar
rodj
Depends on what work you want to do.I use the taller ones because I can pull a trans out on the garage floor
Old Apr 28, 2009 | 12:25 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
The 6 tons will give you enough clearance to do any work to include tranny removal.
If you think you will never do that level of work, 2-3 tons will be enough. These stands are enough to do suspension swap, header installation and all other minor "surgeries"
Old Apr 28, 2009 | 04:00 AM
Weav's Vet's Avatar
Weav's Vet
I have the Advance Auto 6 tons also. They work fine for me. Very well made and support the car great. The only thing I have found wrong with them is when you are lowering the center piece that supports your car........Don't get your finger under it and let it drop when you let it down! I've seen some two tons that I wouldn't get under a car with them supporting it. The base just isn't large enough to suit me.
Old Apr 28, 2009 | 06:17 AM
Epimax's Avatar
Epimax
I've got a 2 ton set (From advance auto) and the HF 6 ton set as well. I used the 6 ton when I had the car sky high for the lowering project, and use the 2 ton for oil changes, etc.
Old Apr 28, 2009 | 06:24 AM
Epimax's Avatar
Epimax
Now, that doesn't sound like fun!
Old Apr 28, 2009 | 06:39 AM
slim jim 2's Avatar
slim jim 2
Old Apr 28, 2009 | 07:25 AM
kalister1's Avatar
kalister1
I have both from HF. I had my 4X4 F150 on the 2 ton set and thought it was a little shaky, they were extended all the way up. I used the 6 ton under the truck and it was rock solid.
Old Apr 28, 2009 | 12:52 PM
NEVRL8T's Avatar
NEVRL8T
I have the set from Harbor Freight in 3 ton. I used them this past weekend. They are orange with white platforms. They work great. No problems at all. I think they are worth the money. This is the only set of jackstands I have ever owned or used though.
Old Apr 28, 2009 | 07:12 PM
DA1984VETTE
Thanks for the response guys. Just needed an opinion on them, I believe you guys answered my question...thanks...
To Jack Stands
