Code 34 Intermittently
Old May 3, 2009 | 06:55 PM
Andyman11111's Avatar
Andyman11111
Default Code 34 Intermittently
Every week or so my service engine soon light comes on in my 88. I checked and its the code 34 MAF sensor. I visually checked the MAF sensor and it appears to be good. My air filter is clean. I noticed that it usually comes on when i have to crank the starter for longer than usual (5 seconds or so). Any ideas? Can i easily test the MAF sensor?
Old May 4, 2009 | 06:22 PM
Andyman11111
Bump
Old May 4, 2009 | 07:14 PM
ShadowC4's Avatar
ShadowC4
Check the pigtail connector that plugs into the MAF. Other then that i don't know of any way to check the MAF itself.
Old May 4, 2009 | 08:31 PM
floridamale's Avatar
floridamale
Try cleaning it get some MAF cleaner spray it let it dry. Clear your codes see it that helps.
Old May 4, 2009 | 09:02 PM
CENTURION's Avatar
CENTURION
My 88 threw those codes when the relays went out, they're not that expensive, you can get them at NAPA. There are 2 of them behind the battery. The MAF can "look" ok and still cause problems. I changed the burn-off relays and MAF and the light stayed off.
Old May 5, 2009 | 04:05 PM
Andyman11111
OK i will try all of this and get back to you guys. How do i clear my codes? (btw the light only comes on about once a month)
Old May 5, 2009 | 05:39 PM
floridamale
Disconnect the battery for a few minutes
If after you clean the MAF and it stays off it's more then likely a bad burn off really. As mentioned earlier.
To Code 34 Intermittently
