93 LCD dash replacement
Old May 8, 2009 | 10:33 PM
tomamy03's Avatar
tomamy03
4th Gear
Default 93 LCD dash replacement
Can any one help us locate a center LCD speedo replacement with out having to replace the whole cluster?? I've tried some of the corvette parts warehouses. HELP!!!
Old May 10, 2009 | 11:37 AM
C4fan's Avatar
C4fan
St. Jude '10
Mine only needed to be removed and replaced. Apparently the connection was needing to be reset. If you haven't removed it, it may be a good place to start.
Old May 10, 2009 | 03:15 PM
gw962's Avatar
gw962
You might try Vette2Vette in the column to the left.
Old May 18, 2009 | 07:27 PM
tomamy03's Avatar
tomamy03
4th Gear
Default 93 LCD Replacement
Thanks I did remove and reset connection on LCD, It worked for about 10 minutes then every thing Froze at 4 miles and hour. Now the screen Reads all 8'
HELP!!
To 93 LCD dash replacement
