Tires for C$
Old May 26, 2009 | 03:38 PM
scotth48's Avatar
scotth48
Default Tires for C$
I have to get at least two tires for the rear and need a set for my original '93 Ruby rims. It seems none of them wear all that long. Original Rims are 8.5" with stock 255 45 17 front and 9.5" rims rear with 285 40 17. I have Z06 rims that were on the car when I bought it. I don't really like them and would like 5 spoke rims that are more conservative looking. All four of those are 9.5" 17 rims with 275 40 17 front tires and 285 40 17 rear tires. My goal is for mileage and something reasonably priced if you can actually say that. Not really interested in tires that can go 160mph. I drive pretty much the speed limit and anything more than that blows my gas mileage.
So what brands/price range/quality/looks/tread pattern etc. do C4 owners reccomend?
Thanks.
Old May 27, 2009 | 10:22 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I'm goin' with the Kumho Ecsta ASX in the 275/40-17 flavor.
Old May 27, 2009 | 12:00 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've had good luck with the Kumhos, I've got Falkens on the car now, I'd never get them again. Lousy wear, no grip, and bad in the rain.
Old May 27, 2009 | 12:14 PM
Alan777's Avatar
Alan777
I'd imagine they have em in your size, I run 255/50/16 the whole way around.
Bf Goodrich g-force sport. I love them, awesome dry traction, pretty quiet.
Old May 27, 2009 | 12:46 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I give a third for the Kumhos. I'm tired of mine, but I need more traction. Otherwise they've been a great tire for the money. I'm stepping up to michelins.
Old May 27, 2009 | 01:10 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Right about Falkens.
Falkens are the worst tire I've ever owned on ANY car. In the rain, you just don't try anything cute or you'll be around a pole
Old May 27, 2009 | 01:13 PM
CedoNulli's Avatar
CedoNulli
I have Firestone Wide Ovals. They are a little more money but grip very well and look good at that.
Old May 27, 2009 | 02:19 PM
onedef92's Avatar
onedef92
Sounds like those ghetto-assed Futura radials at Pep Boys. Had those on my car when I first purchased it. Dry traction was OK, but sucked cold, dead, rigor-mortised donkey ***** in the wet. They turned brick hard after about a year, too.
Old May 27, 2009 | 04:36 PM
LT1CORVETTE's Avatar
LT1CORVETTE
BF Gforce Sports are a good commuter and cruising tire.
BF KDW's are also a good tire for the money.
Old May 27, 2009 | 06:01 PM
Jim Nichols's Avatar
Jim Nichols
Check Toyo Proxies, knockoff of Eagle F-1 for half the price. Had them 3 years, no problems and they ride well since I have a very tight suspension.
Old May 27, 2009 | 06:04 PM
wheelsIII's Avatar
wheelsIII
I've had pretty good luck with Eagle F1's
They aren't cheap - but then you aren't driving a cheap car either...
Old May 27, 2009 | 07:15 PM
samsonb's Avatar
samsonb
Nexen 3000 for my 89 are $120 a piece. I've heard good things about them. And yes, I don't need to pay the extra $$ either for a 160mph tire.
Old May 27, 2009 | 07:30 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I just had a set of Nitto NT555's installed on my car, 285/40-17. Price was $169.00 per tire installed. I believe the 275/40-17's were like $155.00 installed. They are a great tire, quite and very smooth. I replaced Goodyear 275/40-17 F1 D3 tires, they were shot after 25K miles.
Old May 27, 2009 | 07:41 PM
slim jim 2's Avatar
slim jim 2
25k **** i can't 10k from any tire!! and i tried them all
Old May 27, 2009 | 10:28 PM
samsonb's Avatar
samsonb
Actually, I just went out and looked, and my Nexen N3000 tire is W rated. So, that's better than Z rated, which I believe Z rated tires is what was on the car from the factory. And they're AA traction rated.
Plus they look pretty cool.
Old May 27, 2009 | 10:32 PM
Eakster's Avatar
Eakster
My KDWSs have worn pretty fast. This is the all-weather variant that might be different from the KDW, but I wouldn't recommend them for tire wear (or wet-weather grip )
Old May 27, 2009 | 10:50 PM
jimg's'93's Avatar
jimg's'93
I've had the KDW's on several cars and loved the handling but hated the wear. I finally gave up and went with the Kumho Ecsta's and so far I love 'em. Great price too.
To Tires for C$
Old May 28, 2009 | 12:01 PM
Nova Scotia C4's Avatar
Nova Scotia C4
Liked the original Eagles. Replaced the rear tires last year with BFGoodrich G Force SuperSport. Put front ones on last Saturday. Cost in Nova Scotia Canada 210.00 per tire plus tax. Liked the rear, hopefully with them now matched up will be even better.
Old May 28, 2009 | 12:16 PM
CAJUN C4's Avatar
CAJUN C4
I Very Strongly Agree. Great Tire ,Great Treadware
Kumho Ecsta ASX
(Ultra High Performance All-Season)
Overview | Specs | Warranty | Reviews | Test Results | Survey Results
Sidewall: Blackwall
Front: 255/45ZR17
Serv. Desc: 98W Load Index 98 = 1653lbs (750kg) per tire
Speed Rating “W” = 168mph (270kph)
UTQG: Treadwear: 420
Traction: AA
Temperature: A420 AA A
Price: $107.00 (each) Special
Estimated Availability: In Stock
Optional Road Hazard Program: additional $12.84 per tire
Front:
012345678
Rear: 285/40ZR17
Serv. Desc: 100W Load Index 100 = 1764lbs (800kg) per tire
Traction: AA
Price: $136.00 (each) Special
Optional Road Hazard Program: additional $16.32 per tire
Rear:
012345678
Old May 28, 2009 | 06:45 PM
scotth48's Avatar
scotth48
Since the Z06 wheels I have are all 9.5" rims and the '89-92's used that on all four with 275 40 17, maybe that would be a good choice so I could rotate front to rear and get more mileage out of them. I am leaning to the Kuhmo Ecsta ASX. I like the tread as it is more of a highway tread than performance. My current Firestone Firehawks on the front are fairly new and are 275's. I could put them on the rear to rotate them and the new ones on the front. Any input on that?
