Failed electic window
Old May 28, 2009 | 03:08 AM
akmedic70's Avatar
akmedic70
Cruising
Default Failed electic window
Anyone figured out how to raise a defective electric window in a '91? I'm planning to replace the motor assembly but in the mean time I'd like to get the window up. Any suggestions will be greatly appreciated. Thanks - Marv
Old May 28, 2009 | 08:03 AM
runner140*'s Avatar
runner140*
Don't ask me how I know.....get your fingers down there and pull it up.
Ask a friend to use the window button while you are pulling the window-up.
Old May 29, 2009 | 12:03 AM
akmedic70's Avatar
akmedic70
Cruising
Found the problem. Corroded 2-wire connector at the motor relay assembly. cleaned them up with electra-spray and stiff wire brush. All works great now!!
To Failed electic window
