86 corvette heater core/AC electrical problem???
Old Jun 3, 2009 | 01:54 AM
Rollingonhubs's Avatar
Rollingonhubs
Cruising
Default 86 corvette heater core/AC electrical problem???
Hi fellas,
After finishing my nightmare heater core installation, I noticed that my a/c no longer works. I noticed that I disconnected a black wire that runs under the heater core box, its next to a orange wire and a black wire with a "spin on fitting"?
Im not sure what the wire was so I grounded it?
What did I DO?? thanks
Old Jun 5, 2009 | 02:48 PM
Rollingonhubs
Cruising
no help? ttt
Old Jun 5, 2009 | 03:59 PM
SunCr's Avatar
SunCr
The orange wire isn't a wire but a vacuum hose controlling the outside air vent. That's normally open, but HVAC sucks it closed for Recirc or Max a/c. The disconnected black wire looks like the Temp Door motor connector (assuming Electronic Controls). There should be 5 wires and if the Control Panel isn't getting a return voltage (to monitor door position), the OSA LED should be flashing and you won't get a/c.
Old Jun 10, 2009 | 01:18 AM
Rollingonhubs
Cruising
Thanks for the reply SUN,
Ok, went to a shop, he said the vents were probably messed up??
The vent under the dash on the lower right passenger sidewall opens when I put the ac on high, I still cant figure out where this black wire runs too, I figured it attached ontop of round valve used to let air in on the passanger side fire wall?
The lines are ice cold but the vent give out cold air randomly?
Old Jun 10, 2009 | 10:54 AM
SunCr's Avatar
SunCr
Orange goes to the solenoid on the Passenger Kick Panel. Unplugged, if you've got it on 60, the vacuum is doing nothing (other than bleeding the reservoir) and the other vacuum controlled doors might start flopping around.
Intermittent cold/hot is the Temp Door Motor - plug it back in.
To 86 corvette heater core/AC electrical problem???
